Mopar lift spring correction
CincyJLRubi
Cincinnati, Ohio
2021 Jeep Wrangler Unlimited Rubicon
So I ended up getting a Mopar lift. For $1200 new and no shipping I thought it was a good option for now.
I’ve read plenty about it’s shortcomings for hard core rock crawling. Since my use will be mild overlanding it should be fine. If I have to add track bars etc later that’s fine.
But one thing I’d like to do now is make sure install the best spring correction mounts. What should I go with?
Lots of info out there but the kit I’m getting is the newest version so there have been some changes.
acomputernerd
Tricia
Ohio
2021 Wrangler Rubicon
NERD
Its what I installed on mine, out of the box without any correction. If you do add a steering stabilizer to match just make sure you get the older bolt if your is a newer 21 model.
Go bearcats.
aldo98229
Aldo
Bellingham, WA
Market Research
You shouldn’t need to correct for spring bowing on the new versions of the Mopar lift any more.
Mopar redesigned the spring mounts a few months after its release, after it got complaints that the front springs were bowing under load.
I got the Mopar lift installed a year ago: haven’t had to add any correction mounts.
“Correction brackets” is a different story altogether. Many people install “correction brackets” to the front to retain the geometry of the suspension.
Good luck.
CincyJLRubi
Cincinnati, Ohio
Great to hear. I’ve seen previous posts recommending metal cloaks or others. I assume you all aren’t seeing a need for adjustable track bar either?
aldo98229
Aldo
Bellingham, WA
Market Research
Yes. I replaced the OE track bar with an adjustable Yeti track bar. The Jeep came back from the dealer with both front wheels 1.5 inches towards the driver side.
Replacing the track bar is mostly cosmetic, but I had it done when the Jeep went for an alignment.
aldo98229
Aldo
Bellingham, WA
Market Research
BTW, the Mopar lift includes longer control arms. This is done so that there's no need for correction brackets. But a lot of people still go ahead and add them.
I haven’t added correction brackets to my Sahara. They are supposed to correct the geometry for wonderful ride and handling, but they protrude underneath, reducing ground clearance.
I did replace the OE damper with a Fox 2.0 stabilizer to reduce bump-steer —i.e., keep the large, heavy 35s from pulling the steering wheel side-side under heavy braking. And, my Sahara being a 2018, had the steering box TSB done. It now drives as well as can be expected for a Jeep on 35s.
acomputernerd
Tricia
Ohio
NERD
I plan on doing the track bar when I have the funding to change to larger tires and wheels. It does look weird on the stock wheels and tires but it was a choice I made. Right now everything works perfectly and I think it rides better than the original stock setup.
jlajoie03
Massachusetts
2021 JLU 80th Anniversary
Was curious with all the same questions.
I bought the new mopar 2" lift to be put on a 21' JLU 2.0
I also got the fox steering stabilizer
So what is the bolt I need to get for the steering stabilizer?
And with this set up, should everything be aligned, straight, not off center, etc?
Newbie to lifting Jeeps here
CincyJLRubi
Cincinnati, Ohio
Not sure on the bolt as I didn't do the stabalizer.
After my lift was installed the front axle was shifted about an inch and half to the drivers side. I knew that was going to happen so I got a Yeti adjustable track bar and re-centered it no problem. I also then took it to an alignment shop to check everything. My toe needed a slight adjustment from the way it came from the factory since that isn't affected with the lift.
They also measured my caster at 5.3 so adjustable lower control arms may go on but it drives like stock except for a little wandering with uneven roads.
jlajoie03
Massachusetts
Thank you for this!
