Mopar beadlock capable wheels
tjeeper
Patrick
Nevada
'24 392
The beauty rings have to be removed before having the tires pulled off correct? Just figuring this out before I get to the tire shop.
6th Floor Mule
Keith
Woodstock, GA
2018 JLU Sahara 6MT
Some say yes . . . some say no. I removed mine myself to remove all doubt and ensure zero problems. This is one of those controversial topics which will have answers all over the place. Different chains have different equipment, different policies, and different employee talent. I prefer to pop a cold one, break out the quarter inch ratchet, kick some tunes, and remove them myself. Admittedly, I’ve only done this twice, but my strategy remains unchanged.
2nd 392
Ca
Didn't have mine removed when they swapped tires at Discount Tire
DT (AT) removed mine, fortunately they didn’t charge extra, but some reportedly have been. Jeep needs a written policy for us to show tire shops and settle this ongoing issue …… balance issues, or did you reinstall first ?
Mr.Smith
East Tn
2024 Rubicon X
I took mine off to get painted and drove around for a week without them. No balance issues
Byrds8
When they patched a tire for me, they removed mine. But I think its more to do with them being powder coated and I told them to be careful so they didnt have to pay to redo it lol.
Discount Tire
Arizona, USA
discountti.re
All Things JEEP
Tire & Wheel Specialists
Robertyoke
Robert
2019 jeep wrangler jlu rubicon
Did not remove mine when I took the 33" bfg's off and put on the 37" falcon's. No oops no scratches no issues
Tire machine is a triumph ntc910
Old Jeeper
Don
US Army Infantry, IT Engineer
Not sure on "Beauty Rings"
Beadlocks, YES, you must remove the Beadlock ring in order to install tires, even at Discount Tire.
I would take my wheels off and remove the Beadlock ring, then take my wheels and tires down to Discount Tire where they removed the ties and install a new set of BFG KMs. I would pick up and take them home and install my Beadlock rings!
Why? ANY Tire shop should say NO to removing/installing Beadlock rings. They have no idea of the torque required to seat the bolts properly and the ring itself against the wheel. When was the last time the shop calibrated the torque wrench, IF EVER?
You need to know what you are doing and the use of a torque wrench before you jump into running them on the street and trail.
If you are not sure of how to attach that ring and torque the bolts, then just say NO to running them...
PotterJLUR
Kansas
www.youtube.com
2024 392 Rubicon, RAM TRX, Camaro ZL1 1LE
I have mounted A LOT of tires on mopar beadlock capable wheels and have done it both ways but with the trim ring on you REALY risk damaging the tire bead during removal and or install. I would highly recommend removal of the ring to prevent tire damage.
2nd 392
Ca
The rings do not have to be removed for service. I will, however, remove them if a customer requests it.
Not your universal policy as it should be unless changed in the last year as mine were removed without request.
