Mopar 7” light install
Rocknruby
Becky
MN
2021 Rubicon JLU
I have been unable to find the specifics of how to slice the 2 together and then wire to existing auxiliary wiring under the hood. I have seen many videos but none have actually shown their splicing methods. I would like to put them on a quick disconnect so I would like to know what I need and the best way to splice the 2 light wires together and then which disconnect to put onto the aux switch 3 or 4. TIA ?
Dyolfknip74
Ottawa, Ontario, Canada
2021 JLU Rubicon
https://www.wikihow.com/Splice-Wire...he process of,caps to soldering them together.
Then connect positive to aux 3 or 4 under hood and negative to a ground lug.
Make sure you set up switch to behave the way you want it. "latching" IIRC vs momentary.
Rocknruby
Becky
MN
2021 Rubicon JLU
Thanks I have seen all these ways but I need to connect the 2 from lights and then connect to another wire to run to the aux switch wire? I know there’s some kind of splice thingy that you’re supposed to splice one light wire to the other light wire and then run the one you spliced into to the power aux. switch wire? Or there should be some kind of disconnect you can combine both to and then run to power switch wire ? I just need to know what I need to buy to do that. Or can I run both light wires all the way to the switch wire and then combine all 3? If so what quick disconnect can I use .?
Dyolfknip74
2021 JLU Rubicon
I'm not really following what you're asking. Splice the 2 power wires together. Then solder another wire to it to carry positive to the switch bundle.
As for the quick disconnect, why do you want to add that inline? There are numerous types of "disconnects" you can use.
Do you have a picture of the harness? Or maybe a drawing of what you're asking?
