Missing hood release lever & sticky spring
LuvHydro
Midwest
21 JLUS Hella , 22 JLUSS Hydro
Anyone else keep reaching inside to unlatch the hood? DOH
Hard habit to break.
Also, when I do raise the hood, the rubber bumper on the hood spring sticks then comes free and goes "Sproonngg" (think Don Martin)
Anyone else's stick?
JasonInDLH
Jason
MN
21 JLUR, 15 Yukon Denali
I’d Rather Talk Jeep’s!
My spring does the same. I’ve had it in the back of my mind to fix it one of these days.
mdkautzman
Centralia, WA
2021 Jeep Gladiator
Yep. Mine too. It seems to get caught in the plastic trim towards the engine side because the round cut out is to small.
LuvHydro
LuvHydro
Midwest
That's what I thought at first on mine. On mine the rubber bumper actually sticks to the place it rests on.
The reason I know that on mine, is was stuck so bad after I cleaned it off, that it stretched the spring way out and wouldn't let go.
AFD
Northeastern US
2023 JL Rubicon (2DR/V6)
Is there any recommended way to adjust the hood spring by the release lever?
Mine always catches on the front trim piece attached to the grille and eventually "boings" loose once I get it pushed out of the way. Just afraid of eventually stretching out the spring too much or breaking it off the hood. Just bend it maybe?
mini4mw
Atlanta
Jeep 392
I thought it was catching on the lever to push sideways.. the safety latch. Guess I need to investigate now.
AFD
Northeastern US
That might be how mine's catching too, I'm not 100% sure. Just felt like it was getting hung up somewhere at the front of the spring.
mdkautzman
Centralia, WA
2021 Jeep Gladiator
It's not catching. It's getting stuck. I added a black adhesive sticker to the bottom of the rubber and fixed!
  • Like
Reactions: AFD
AFD
Northeastern US
The bottom of the rubber pad is getting sticky and sticking to metal of the body/engine bay? That would make sense, but I seem to recall that even after it's loose, the rings of the spring still catching a bit on something.
Wonder if coating the bottom of the pad with a grease would also keep it from sticking or if that would make it worse?
Opus
Midwest US
www.jlwranglerforums.com
Mine does. The spring actually makes a noise every time the latch catches it.
  • Like
Reactions: AFD
