Redx2
- Heather D
- Aug 18, 2018
- High Desert
- 2018 JLU, 2018 JL
I'm trying to avoid a trip to the dealership. If there is anything you think I'm missing or should try please advise.
Yesterday I went to take my top down - I unlatched the front then pulled back so it was bunched up along the top rear but instead of staying horizontal so I could release the lever in the back to pull it down, the back portion just immediately fell limply. Then it was stuck in this position:
We were able to get it all the way down with 2 people pushing. Fast forward to 3am, its raining & I run outside to pull the top back up. Yes, I flipped the 2 locks first. This time it got stuck in the half-way up position where the top is hovering vertically in the air like a sail. 2 of us got it to come down but it wouldn't go forward enough to engage in the front. I'm in the desert and a full time soft top driver, this is not an issue of it not being warm or stretched out enough. This AM I noticed each side is sticking up & out like this:
I pulled it back & noticed this plastic thing I've never seen before on each side causing it to stick out.
These things on both sides are loose & can easily be pulled out or removed:
The back release lever no longer pulls or does anything. Nothing seems bent, snapped, or out of place. We were doing some trails & crawling this weekend (top in safari mode) & we bumped around a lot so I'm hoping maybe it's as simple as something having been bounced out of it's position but everything appears to be on its proper track. Any ideas?
