58Willys
- Geoff
- Jan 2, 2022
- Western Washington
- 2018 JL Sport
Pull spark plugs on the passenger side (much easier than drivers side) look for one plug that is shiny clean; if so that’s a sure sign of leaking head gasket. If you have a bore scope, pressurize cooling system and see if you see any coolant leakage into the cylinders. Also check for very clean piston tops, hot coolant in the cylinders will steam clean things.Wow. Well, I don't have any coolant smell, no misfire codes or issues at startup. But I guess anything's a possibility. I'm still holding out hope though lol I'll be checking the level again this afternoon. If I see a drop I will start with a pressure test and go from there.
