onepoundjeep
(can't make a poll for some reason)
If you have to choose Mickey Thompson Baja Boss AT at 285/70R17, at Discount Tire there are 2 options, Load Index either SL or E? Which do you choose?
Am curious on people's thoughts about my situation or for other setups similar too. My Jeep is mainly daily driver. Its a 2door sport, manual transmission, with 3.45 gearing. I have no plans to go bigger than 33" tires. I have not had many opportunities to offroad yet, but want to do more, attend a jeep academy event and go to other places than hidden falls adventure park.
Some of the specs of each:
SL - 48 lbs, 16/32 tread depth, 2756 max load, 44 max psi
E - 63 lbs, 18.5/32 tread depth, 3195 max load, 80 max psi
My thoughts for my situation: I figure being mostly daily driver, cuz 3.45 gearing and because its a 2 door, the E rated would be way too stiff and heavy, where i would feel every bump no matter how low my air pressure is, and would be lugging around in 3&4th gear all the time cuz the tire is so heavy. But then i see so many threads about people saying don't do SL or P tires. But for this choice I think I would have to do SL rated unless i want to do gearing change. I wonder are some tires in SL or P rated ok to use, like Mickey Thompson AT or Toyo AT3, and just need to be more careful on rocks...
