grimmjeeper
- Roy
- May 6, 2021
- Castle Rock, CO
- Website
- www.grimmjeeper.com
- 2021 Wrangler, 1987 Comanche, 1997 F250
- Build Thread
- Link
- Occupation
- enginerd
Not always.LSD = 4WD Auto correct?
LSD is Limited Slip Differential. It's a mechanism inside the differential to help keep the tires on either side of the axle from free spinning. It is a purely mechanical system (clutches or helical gears) that has no direct computer control applied to it.
4wd auto is a setup in the transfer case to let you run 4wd on pavement without binding. It's essentially a differential inside the transfer case. In the JL, there is a computer controlled system to bias the torque and prevent slip.
4wd auto comes with open diffs. You can add LSD to one or both axles and it will help make the computer control more effective.
Some systems like QuadraDrive on the Grand Cherokee have a computer controlled torque biasing differential in each axle. That's different than a mechanical LSD. Adding that to a JL is more complicated than it's worth.
