Loose Steering
Wobelnik
Jorge
Tampa Florida
2018 Wrangler Rubicon New Unlimited JL Sport
I have a new to me 2018 Wrangler Rubicon JLU. My first jeep. I experienced the death wobble 3 times in my first month of ownership. After reading many threads, and I thank yu'all, I installed the synergy steering box bracket cause I'm out of warranty with 135,000 miles. I also added a steering stabalizer. So far so good, no death wobble.
But, my steering seems to have to much dead space and it likes to wonder more than I'm confortable with. Whith no apparant worn parts, what would be my next thing to consider or is this just a Jeep thing and I should live with it?
BDinTX
Dallas, Tx
What size tires and what air pressure are you running? Most dealerships over inflate the tires.
TopWright
Richard
Western NC
2019 Rubicon JLU Granite Crystal Metallic
USMC (Ret); IT Specialist K-5 Public School
My 2019 JLUR has a bit too much play in the steering to my liking also. I can turn the steering wheel left and right from center about 1.5" with no movement at the pitman arm. I checked and I have the aluminum steering box. I will have the steel box installed soon. From what I have read that should help me.
Wobelnik
Jorge
Tampa Florida
Tire size are 35 with spacers. more than half worn but pretty even wear.
BDinTX
Dallas, Tx
What tire pressure?
We run 30-32psi on our 35” BFG KO2 AT
OUr 37” Mickey BB MT are at 28psi
These are regular pressures, on road, highway, etc
Wobelnik
Jorge
Tampa Florida
What tire pressure?
Are you saying that 35 psi in 35's can cause loose steering and or wondering. Thanks, I will try 30psi. and we shall see.
oldcjguy
Jim
Central FL
16 Challenger Hellcat, 19 Challenger Scatpack, 20 JLUR Recon
Software Engineer
On a 2018, 2019, and 2020, unless it's been replaced, you have the aluminum steering box. With that many miles it's probably got some play since they had play new. That's where the "dead spot" in steering most likely comes from. There was an update to a cast iron box that helped the steering play.
For death wobble, check your ball joints. At over 100k miles and 35s you're probably due.
BDinTX
Dallas, Tx
No 35 psi is probably not a problem. Some people have 45 psi in 33" tires which will make it feel flighty. Just wanted to rule out the simple stuff. It's probably the steering box or worn track bar bushings.
TectonicDiscoveries
2018 Wrangler JLU
What steering box do you have? Cast iron or aluminum? You can pop the hood and see if its black or silver to tell visually given the year.
I had the aluminum and if felt like a good 1 1/2" of deadzone in the middle. Did the whole steering stabilizer and all prior, but when the cast iron box went in it drove like a whole new Jeep. Maybe 1/4" of deadzone now.
Wobelnik
Jorge
Tampa Florida
aluminium and added the synergy bracket cause i am out of warranty. And yes it helped.
Wbino
NJ
Amazed how people trade in a Jeep with no mention or care what the next owner will have to deal with.
Same could be said to about a dealer who sells it w/o a care.
Selfish.
TectonicDiscoveries
2018 Wrangler JLU
If that helped then it may be the culprit. When I was searching youtube and forums I saw a lot of post at the time (2020) noting the synergy brace helped, but moving to the cast iron steering box eliminated the problem completely once that became an option. It sucks to pay for out of warranty and had to take it in because there is supposed to be a software update with the swap. Couldn't get confirmation on if its fine without the update but has something to do with how long the pump runs to cool it. It's been one the best worst things I've to do in terms of drive-ability.
It's TSB 08-074-20
(Edit: Clarifying that the culprit being the steering box, not the synergy bracket directly)
rickinAZ
Rick
Phoenix
2026 MOAB 392
Selfish.
Agreed. But we have to remember that in this case the Jeep has 135K miles.
Upnarms
AZ
2019 JLUR, 2003 TJ X
Why did you post this under two different titles? Just to add more evidence to your other title about if death wobble/ steering is the most common thread? Yes, and congrats for allowing it to stay that way
Wobelnik
Jorge
Tampa Florida
WTF, what do you mean? I'm new to this forum and find it a bit confusing. Sorry for the inconvenience.
