Looking for an approximate height
MTBMike
Ca
2019 Jeep Rubicon - 2 Doos
I have 2019 jeep jl rubicon 2 door and I am going to run a 4.5 inch lift with 40’s. Anyone out there know the approximate height of the roof after the work is done.
Thanks
Old Jeeper
Don
US Army Infantry, IT Engineer
Thanks
Its going to set approx 7.5 inch higher than it is stock, might want to measure you grade door...
MTBMike
Ca
Thank you - that helps a lot
Headbarcode
LI, New York
2019 JLUR Stingray 2.0 turbo
Thanks
My 19 JLUR has the 4.5" Metalcloak Gamechanger and 40x13.5 Milestar Patagonias. It sits about 81-81.5" tall at the highest point of the hardtop.
Jeep Wrangler JL Looking for an approximate height 20220806_091606
Jeep Wrangler JL Looking for an approximate height 20230622_065704_resized
Jeep Wrangler JL Looking for an approximate height 20220806_091830_resized
Different brands of lifts will net different actual height increases, because some are designed to support more weight before sagging below the advertised height. My previous 3.5" Metalcloak springs netted about 4.5", and the Jeep sat pretty damn level. Their 4.5" springs netted 5.5" up front and 6" out back, giving a slight rake.
Here's some measurements of the front 4.5" springs, taken from the top of the axle tube to the outer lip of the upper spring bucket. It's the most accurate way of gaging actual ride height increase before and after a lift is installed. Jeep is on level ground.
Jeep Wrangler JL Looking for an approximate height 20220806_090732
Jeep Wrangler JL Looking for an approximate height 20220806_090850
drtrdr85
Aaron
Bay area, CA
2020 JLUR
If it helps, I am running MC 4.5 and Nitto 40s and mine fits in my garage which is 7 feet tall.
MTBMike
Ca
Thank you both - the pictures and the info on metalcloak was exactly what I needed - this form is great. Again thank you both.
I will update this thread by the end of the week - jeep should be done. - Hoping so at least.
