Scarr2k
Thanks for the tip. Prob no rock crawling for me, but definitely would be concerned if I was and how close they get to the body. Barely get the top of my finger between the front passenger end and the body of the Jeep. Definitely if it flexed hard it would damage the Body.Not sure what your repositioning method was, but make sure and put some large washers up front against the frame where you had to drill the holes. This will help keep it off the body as the sliders flex. Even then, mine bent up into the body and creased both sides of the Jeep the length of the sliders. If you aren’t going to hit them on rocks you’ll be fine
not sure anyway to push it out more since if you do then the only bolt holding it as seen in the yellow circle wouldn’t align with the hole. Like you said I assume I’m fine as long as I’m not rock crawling.
