Lets talk Dead Pedals
SoCal JLUS
Inland Empire (Greater Los Angeles)
2021 JLU Sahara 2.0T
Got the same one, works great, easy install, nice price, and plenty sturdy. It also has a variety of mounting lengths/angles so you should be able to adjust it just where you want it.
Lol, your post in another thread is what inspired me to find that particular brand. I copied you!! ?
gerrya
Gerry
Putnam County NY
Willys
After seeing this thread and missing the dead pedal I ordered the M.O.R.E. pedal from Quadratec. Install is not that bad, even had to take it out to adjust it to the closest position. One thing to note is if you look at the outside of the Jeeps kick plate with a mirror you will see that about 1/4 of the backing plate does not make contact with the kick plate due to the way it is molded.
I wouldn't worry to much about dropping the backing plate, it cant go that far and would be easy to fetch with a magnet.
Jeep Wrangler JL Lets talk Dead Pedals Pedal
Jeep Wrangler JL Lets talk Dead Pedals Holes
MRMDFY
Gitmo
Shadowbanned and taking the bus
Does the gap bother you enough that you'd advise stacking washers in there? My impression is that it's quite solid without, but I'll be installing mine sometime in the next few days.
gerrya
Gerry
Putnam County NY
Willys
Its plenty solid. I just tightened the nuts until there was no longer a wobble in the pedal. I sent MORE an email with the pic, was just curious if maybe that frame used to be flat and the newer models is different.
Jim_n_Tx
Jim
Texas Gulf Coast
TJ, Commando, JT , JL, M422
I was bummed to discover that a manual trans JT (and I guess, the JL) does not have space for a dead pedal. I have one in my TJ and use it. Also put one in my wife's two-door JL. Interestingly enough, in another vehicle of mine (manual trans) the pedal is described in the owner's manual :
Jeep Wrangler JL Lets talk Dead Pedals IMG_20220203_215446_kindlephoto-1166236622
elPollero
Anthony
TN
2021 Jeep Gladiator Willys
Installed my M.O.R.E yesterday.
Only problem I had was the bolt pattern on the back plate was a hair wider than the holes. Screwed up and pushed the bolt closet to the door in first then couldn’t get the back bolt to go in. It wedged in there and about never got it out .
recommend test fitting the back plate from the front before getting it behind the the factory bracket.
Took a rat file and turned it around in the hole a few time and it slid right in.
Made the install easier because the plate wasn’t moving after I got it through the holes.
Does have a small gap in the back bolt on the back side due to how the mounting bracket is made but it’s has no play at all.
Put mine on the highest bracket hole. I like my legs bent a little. 6’0” and keep my seat all the way back
gerrya
Gerry
Putnam County NY
Willys
Same here with the holes, once I got it in I couldnt get it back out so I just pulled it in with the nuts. I also used the closest to the seat hole for the pedal, started with the middle and it felt to far so moved it closer.
jmccorm
Josh
Tulsa, OK
2021 JLUR
Systems Engineering
I will forever misread this to be a thread about dead pixels in the uConnect radio, only too late to discover yet again that I've instead fallen for this suspiciously close yet entirely unrelated topic.
RevKen
Ken
Iowa
2019 JL
JAF1
Pittsburgh, PA
2021 JLUR (RIP)
Just as a quick update. I talked to someone over at Quadratec this morning, they still don't have an estimated delivery and there are over 500 on back order.
Funny how quick things change. After being told they didn't have an estimated delivery just last week, it shipped the next day and I had it the day after. Wow. This is from a early October order.
blnewt
New Mexico
Just ask @cosine he knows!
Maybe a thread on jlwranglerforums.com is all it took to kick this into high gear :)
