SadRobot
- Aug 31, 2019
- Los Angeles
- 2025 Prius LE
Around 2 years ago I took my Jeep to a shop and they drilled a hole in my firewall. The ran a bunch of switch wiring and air locker lines through it, no grommet. I discovered this about a year ago when I re-routed my switches and air locker lines.
I decided to re-use that hole since it's there now to run my antenna wire through the engine bay to mount. It's been fine for a year or so but really there should be a grommet in there so that brings me to today.
The antenna wire has these connectors on the ends. I don't believe I can separate the wire from these although I could be wrong on that.
So whatever grommet I use this black smaller end has to fit through.
This is the grommet kit I own already.
The closed grommets are too big but I could buy ones that fit the hole, slice a large vertical line into it and push the black connector end through.
Or I combined 2 grommets, sliced the side and that seems to hold fine. Are there any issues with the way I did this? Is the closed grommet with a slice a better idea?
