LED tail light ring out
T-Macc
Tyler
2022 Jeep Wrangler Rubicon
I see many posts here about this happening but never see an end result or what was done to fix it? Anyway, my driver side running light randomly went out on my tail light. They are the stock tail lights and I have a 2022 rubicon. Anyone have this happen to them? And what was done to fix it? Seems to be an electrical issue but must be coming from the factory because I see same situation with many people online. Thanks for any help or info you have!
Xorak
TN
2020 Hellayella Sport, 2023 Reign Sahara
Most likely the tail light will have to be replaced. Hopefully you're still under 36k miles so warranty will pick up the tab.
T-Macc
Tyler
I am! Got 16000 hopefully that fixes it tho. An electrical problem can be a real pain in the arse
Jeepfueledbydiesel
Nick
Wilmington NC
2022 Wrangler Rubicon, 2023 Wrangler Rubicon 4xe,
Old thread but I just got a used 22 and my driver side tail light is out. The rest work. I checked and it is getting power to the light. Since I'm out of warranty anyone know where I can get one at a good price. Seems most want $640 or more. Mine has the BSM as well, which adds to the price it seems. The dealer here want's $1,023. Part number is 68474045AD
ORACLElights
Peak Sponsor (Level 2)
Metairie, LA
www.oraclelights.com
2019 Jeep Wrangler JL
Automotive LED Manufacturing
Could always move over to the ORACLE Lighting JL Flush Tail Lights. For the pair they will be considerably less expensive than the OEM replacement. They feature a form fitting that protrudes significantly less than OEM. The reverse lights are extremely bright. The BSM sensor can be swapped over to the Flush Tail Lights (if equipped). Available in Red or Tinted Lenses.
Jeep Wrangler JL LED tail light ring out ORACLE_Lighting_Jeep_thelunartik
Infotainment
Summit Sponsor (Level 3)
Infotainment
Oviedo, Florida
infotainment.com
Various
Infotainment.com
$620 is the best price I see via retailers. If there is nothing wrong with the BSM module then you can buy the light fixture minus the BSM module and swap yours over to save a few bucks.
Jeepfueledbydiesel
Nick
Wilmington NC
I was looking at them and then found a set of OEM on marketplace at a great price. Thanks
