GMONEY
- Greg
- Sep 24, 2022
- Temecula California
- 23 2D Rubi Earl
First after a month and about 1400 miles the stock carpet mat I had was already starting to get a heel print in it as you can see below so I needed something.
I lucky enough to get a pre-order set of the upcoming Lasfit floor mats. The whole set (for a 4 door) came in 1 box that was pretty robust and I know it'll take a beating and jeep everything inside safe. The front mats had very little deformation from shipping and the rear mat was folded in half. No need to lay them in the sun or anything just need to roll them back on themselves where the deformation is and they spring right to where you need em.
Not much else to install (they are floor mats adterall) except to make sure you put them in on the right side. If you do grab the wrong one it will take about 30 seconds (of that) to realize. They snap right into the factory connections.
Here is the driver side Lasfit mat
Now Passengera
These things fit great both width and length although I would like to see just a bit better fit around the seat mounts on the outside of either seat. As you can see in The below pictures it doest quite for around that mount.
I'm not sure if this is because I have a 2 door and this full kit os for a 4 door though I do believe the Fronts are the same but you never know.
Overall I like the fit and am happy with it and I think if LasFit were to separate the Fronts and sell as for a 2 door any owner would be happy if they purchased them.
I think they'll be fine in just about anything I get myself into they have deep grooves to funnel anything wet away and they snap in and out overall are a good product.
The rear obviously isn't going to work in the 2 door but it looks like a pretty good product with easy installation as well for those of you in the boxy minivan that can go off road.
Now Passengera
