Larger Rear Storage Cubby
oceanblue2019
Maryland
2019 JLUR 2.0L Auto
Metrology
I got the plasma table set up. Next step is to get my cardboard mock up entered into the CAD program and cut the first one out. That probably take another month.
You willing to do some custom work with that bad boy?
Glamisfan
Glamisfan
SoCal, 30 minutes from Glamis
2020 Sting-Gray JLUR
I’m too new at using this fancy equipment to say yes! Lol. Give me some time to see how it goes.
Glamisfan
Glamisfan
I’m waiting for a windows computer so I can start using the plasma table. And I’ve been focusing on my Jeeps suspension. Should be done with the suspension in 2 weeks. So probably a few more months.
four low
central New York
2018 JL
Thank you for taking this on, a bolt from underneath box will be fantastic. A Marine Hatch and storage cubby might work too, on West Marine website " access hatch liners "
Glamisfan
Glamisfan
Sorry, it’s going Hella slow! There’s a pretty steep learning curve on how to operate a CNC plasma table and how to do CAD programming. And I am new to both of those. I started working out the dimensions in the CAD program but hit a wall. Plasma table is at my side job which I only spend about four hours a week at. I’ll get there one of these days though and I’ll update when I do. Thanks for the interest!
sourdough
left coast
JL
Great thread, I missed this one and just found it. I thought about this also and noticed if the sway bar was deleted with a RockJock through the frame unit. A much bigger box could be added. To far into good wheeling weather now. Next winters project haha.
Glamisfan
Glamisfan
Yup. That sway bar makes it a pain to design and make. I‘ve driven mine with the rear sway bar disconnected, and I couldn’t feel any difference. After I get the regular version made, I plan on making an even bigger one for mine whith no rear sway bar and the 1 1/4” body lift I have!
R00STER
Rich
STL
2021 JLUR 3.6L - 6sp
I know I'm jumping on here late, but in line with The Last Cowboy's suggestion for keeping it simple, would it be possible to just extend the existing tub.
I don't have a specific solution for this, but it would seem that it you cut it laterally, then you could just add in any length you need using PVC stock sourced from home depot. The only challenge would be to bending the PVC board to match the rounded corners, but that should be achievable with a heat gun and clamps. Add some epoxy and sealant and it should would be water tight. To increase strength you could always add aluminum or SS pop-rivets
By using the existing plastic tub, you would keep the benefits of a drop in solution and keep the weight down.
four low
central New York
2018 JL
Another way to gain more storage,after the muffler delete, is to cut the bottom only out of the cubby, and add a drop- in " access hatch liner", or a Tote with a flanged edge.
This would deepen the storage area, and be reversible.
Once mine is paid for, this will be my method.
Glamisfan
Glamisfan
Sorry, but life is just too damn busy…..haven’t built the first one yet. I’m for sure going to build one for me, and I’d like to make them available, but not sure if it’ll ever happen? I did have the thought recently that it could be a lot larger, and more rectangular, if I were to make it bolt on from the bottom only. That way it wouldn’t have to be able to slid in from the top, which limits the size. I’ll update when any progress is made.
And I am still surprised that no company has attempted this yet. Way easier than it was on the JK.
