KC HiLites Flex Era 4 install
Silent Panda
Jason
Salt Lake City
2018 JL Rubicon
I got my Flex Era 4's installed this week. I was going to use a Switch-Pros PDM for power supply and switching but I won't have it in time for EJS. So...I did a standard install using the included switch and wire harness.
I went with a cowl location for my install and used the mount from Rock Hard 4x4. I liked that it wasn't some big ass bracket.
The adapter
Jeep Wrangler JL KC HiLites Flex Era 4 install IMG_0316
To use the adapter and have light bracket centered, I modified the carriage bolt that came with the lights by cutting a flat on the face, drilling a hole thru it and and cutting it off after the square.
Jeep Wrangler JL KC HiLites Flex Era 4 install IMG_0315
Jeep Wrangler JL KC HiLites Flex Era 4 install IMG_0314
On to the install...
I ran the wires for the switch and the driver's side light through the plastic wire track on the firewall.
Jeep Wrangler JL KC HiLites Flex Era 4 install IMG_0310
I ran the switch wires up past the lower windshield seal.
Jeep Wrangler JL KC HiLites Flex Era 4 install IMG_0309
Jeep Wrangler JL KC HiLites Flex Era 4 install IMG_0311
I mounted the switch below the headlight switch. It was a good spot to plug when I go to the Switch-Pro.
Jeep Wrangler JL KC HiLites Flex Era 4 install IMG_0312
Jeep Wrangler JL KC HiLites Flex Era 4 install IMG_0321
After trimming the harness, I mounted the relay in the passenger side cowl using an existing body bolt.
Jeep Wrangler JL KC HiLites Flex Era 4 install IMG_0313
Tested the lights then buttoned it back up. Here is the result.
Jeep Wrangler JL KC HiLites Flex Era 4 install IMG_0319
Jeep Wrangler JL KC HiLites Flex Era 4 install IMG_0318
Jeep Wrangler JL KC HiLites Flex Era 4 install IMG_0317
Jeep Wrangler JL KC HiLites Flex Era 4 install IMG_0322
Princeton New Jersey
2021 JLURD
Thanks so much for this Silent Panda! Installed mine this weekend using your wiring path and was a big fan. Added some of my own photos below. Also, I ended running the power to aux switch 1 and keeping the KC switch as well. Given how bright these things are, I like the double contingency of having to ensure the aux switch is enabled before turning on brights or ambers. Afraid my wife will accidently hit the KC switch and then not know what to do to get them off.
Jeep Wrangler JL KC HiLites Flex Era 4 install IMG-2634
Jeep Wrangler JL KC HiLites Flex Era 4 install IMG-2635
Jeep Wrangler JL KC HiLites Flex Era 4 install 66206533240--1CB31E06-2952-44E1-87B0-773141205A3F
Jeep Wrangler JL KC HiLites Flex Era 4 install RenderedImage (1)
Silent Panda
Silent Panda
Jason
Salt Lake City
2018 JL Rubicon
Nice work PavementAbsurdity. Glad me install could help someone.
Fortunately, I'll be undoing a bunch of my wire tucking when I install a Switch Pros to control air lockers and such...
