JLU Sahara Lower Control Arm length
RockinMarine
Cary
Menifee CA
2018 Jeep Wrangler Unlimited Sahara JL, Firecracker Red
Retired Marine/ Techician for Disney
I need some help. I have an 18 JLU Sahara currently with a Mopar 2" lift. Unfortunstely I threw out my factory control arms. And I need to length. Does anyone have a set of factory Lower Control arms for a JLU they can measure the length for me. I need center to center bolt distance.
GATORB8
CLT NC
21 JLURe, 06 LJ, 25 HDZR2
Should be 24". Mopar LCAs are 24.25".
rickinAZ
Rick
Phoenix
2026 MOAB 392
With a 2" lift the standard length LCAs will be too short. Go with the 24.25"s or adjustable LCAs.
cobra
So Ill
2021 Sahara
I have the ones i just took off my 21 sahara to replace with the mopar 2" lift ones. They are 24" on center.
rickinAZ
Rick
Phoenix
2026 MOAB 392
Issue is that he has a 2" lift also, and he'll need the longer LCAs for exactly the same reason that you have them now.
GATORB8
CLT NC
He has them already, they’re part of his lift. He’s just asking what stock length was.
RockinMarine
RockinMarine
Cary
Menifee CA
I bought adjustable LCAs. But I also have goemetry correction brackets. And with the added length of the longer LCAs, my axle is pushed too far forward causing steering float from too much angle. It was recommended to go back to the factory length, hense why I needed the measurement, so I have a starting point to install my adjustable LCAs.
