JKS Fixed Length Front Lower Control Arm.
bosshogs
Henry
Oviedo, FL
Wrangler JLUD
I had a JKS JKonnect 2.5' lift kit installed on my 2022 Wrangler JLUD at a local shop and after install was completed I took the vehicle and got an alignment done. On the way home from getting the alignment done, everything seemed good until I was on the highway and was going about 70-75 mph and started getting the dreaded death wobble, slowed down to about 65mph and it went away. This only happened after going above 70mph and only a couple of times. After getting home safely I took a look at the instructions that came with the lift kit and it looks like the lower control arms were installed backwards.
This is directly copy and paste from the Instructions:
Establish control arm orientation. The arms should be mounted so that the bend goes inward (away from the tire) and the end closest to the bend mounts to the frame.
Taking a look at how the control arms were put in the vehicle, the end closest to the bend was mounted to the axle.
Jeep Wrangler JL JKS Fixed Length Front Lower Control Arm. IMG_0683
Every YouTube video I have found about installing these control arms are for a JK or older and the end closest to the bend is mounted to the axle on those, I cannot find one for a JL. Can someone with more knowledge provide some guidance here please.
Hucke_250
Ohio
2018 Unlimited Sport
Have you gotten underneath the Jeep and measured from the bend to the bushing? From the picture you posted it does look like they are mounted backwards, but measuring would confirm this.
bosshogs
Henry
Oviedo, FL
Wrangler JLUD
Yes, from the axle to the bend it is 10’ and from the frame to the bend it is 15’. I have been told by a few others on Facebook that the end closest to the bend should be mounted to the axle and it is correct. But the instructions clearly state for the end that is closest to the bend should be mounted to the frame, so I am confused.
Maverick909
I.E.
www.instagram.com
That’s because they swapped the driver and passenger side. The closer bend is to the axle but on the wrong side
Hucke_250
Ohio
I’d reach out to JKS to find out if the mounting the control arms backwards could effect castor, tire clearance, or both. I’d also check that the control arm and track bar bolts are tightened to spec.
Did the shop provide you with an alignment sheet showing what your current castor is?
bosshogs
Henry
Oviedo, FL
Wrangler JLUD
I had to take it to get an alignment from a different shop because the shop that installed the lift didn’t have alignment equipment. I plan on reaching out to JKS tomorrow and get clarification on the mounting part. Here is a pic of the alignment print out.
Jeep Wrangler JL JKS Fixed Length Front Lower Control Arm. IMG_0685
Jeep Wrangler JL JKS Fixed Length Front Lower Control Arm. IMG_0686
Riotfunk
Ma
22 Willys with 2 Doors
Death wobble is usually gonna be track bar related. Not torqued enough especially frame side. Hole is wallowed out. I’d pull the bolt and check the mount and the TB bushing. It doesn’t take much to mangle it if it isn’t torqued enough
bosshogs
Henry
Oviedo, FL
Wrangler JLUD
Just got off the phone with JKS and they said the instructions are correct, the end closest to the bend should be mounted to the frame.
Remorseless
NC
Have those arms and yes, the shop put them on the wrong sides.
GATORB8
CLT NC
21 JLURe, 06 LJ, 25 HDZR2
This kind of sounds like balance to me. It's repeatable at the same speed without external impact?
Maverick909
I.E.
www.instagram.com
Opps. That’s what I meant! Went out and looks at my Jeep lastnight my apologies!
bosshogs
Henry
Oviedo, FL
Wrangler JLUD
Yeah it only happens when above 70mph and if I hit a small bump in the road. Never happened before lift install so I assumed it was something to do with the lift components.
GATORB8
CLT NC
10-4, bump in the road points to the components. I'd check the track bar sooner than later so you don't get any wallowing if it's loose.
bosshogs
Henry
Oviedo, FL
Wrangler JLUD
Would you happen to be able to measure from the end that is mounted to your frame to the bend on the LCA and measure the end that is mounted to your axle to the bend and post that here? Mine are axle to bend 10' and frame to bend on the LCA is 15'.
Remorseless
NC
I can tell you without his measuring that yours are on the wrong sides. The JKS sticker is at the axle side when installed correctly, not the frame side:
Jeep Wrangler JL JKS Fixed Length Front Lower Control Arm. 1684163097750
Jeep Wrangler JL JKS Fixed Length Front Lower Control Arm. 1684163116326
