Avar928
Currently a bit over 94,000mi on my 2018 2.0 JLU with ESS/E-torque. I have an AllData monthly subscription and setting up to tackle the chain tensioner replacement. Anyone else do this job? I see at least one thread but not many others.
Other reference threads:
2.0T timing chain replacement | Jeep Wrangler Forums (JL / JLU) -- Rubicon, 4xe, 392, Sahara, Sport - JLwranglerforums.com
https://www.jlwranglerforums.com/forum/threads/2-0t-tensioner-chain-rattle.119867/
- Cylinder Head Cover
AllData states to remove the cylinder head cover but I want to avoid this as it requires replacing the high-pressure fuel line. How much harder is the job without removing this?
- Vibration Damper
Can regular tools be used to remove this or do I need to buy 2054400090/ESS or 2024800090/Etorque Damper, Holder Shallow and Deep? If any can recommend non-Mopar cheaper specialty tools I'd appreciate it.
- Timing Chain
While chains do stretch and this would be a good WYAIT, is a chain change imperative (e.g. how much longer would a timing chain last before a replacement is needed?)
- Oil Pump Chain Tensioner
Also a WYAIT, critical to replace the oil pump chain tensioner and or chain as well?
Oil Seal Installer 9506eBay to the rescue, used 9506 for $13 + free shipping
Seeing a range of prices for oil seal installer 9506 for timing chain cover ranging from $13-120. Can I use a generic tool instead?
