JKS Disconnects Install
ResqFE
Ron
Ensenada Baja MX
2018 JL Unlimited
JKS recommended the shorter quick disconnects for my Mopar lift on my 18 JL Sport. The right passenger side has increasingly been harder to get on the pin to secure. Then I noticed the quick disconnect isnt vertical. Verified the install with washers, spacers, and bushings. Stumped.... any help is appreciated.
Roky
Roky
Jeep Wrangler JL JKS Disconnects Install 20210328_095745
JKS is basing their recommendations on the advertised lift height of 2”. I’m sure with a sport, you got closer to 3.5 or more. Is your sway bar level or pointing down slightly at ride height ? If so you need to lengthen them or get longer ones so it’s pointing up slightly 7-10 degrees ish...
