JK to JL compatibility listing
four low
central New York
2018 JL
The TPMS frequency changed in 2013. So they are NOT the same as earlier posted. 2013 to 2018 JK same. 2012 and prior different frequency.
Riviera
Illinois
2022 JLUR 2022 WL75
My apologies, 68241067AB is the tpms sensor. I did a cursory look and that part has been used by mopar in some fashion since 2010. But as four low posted, 68241067AB is 433mhz and has only been used on Wranglers since 2013, before that sensors were 315mhz
But 68241067AB is the sensor listed for JL Wranglers, so those ARE the same as 2013 & newer Wranglers
jericbarg
Rainbow City, AL
JLUR-Granite
Healthcare
Jeff,
I have a correction.
We went to install a budget boost on another JL today and the rear springs are smaller than mine, therefore JK rear spacers upper or lower will not work on all JL's.
I know of 4 others that have installed them with no issues, but it seems JEEP made a running change or just used up what JK stock was available.
Therefore we have to state JK rear spacers upper or lower may not work so no one will buy them in error.
Measure you springs JK uses a 5 5/8 diameter spacer and some later JL's use 4 1/2inch.
This is a bummer.
the last 4 of my VIN is 0028 which shows it was the 28th produced.
Jeep Wrangler JL JK to JL compatibility listing IMG_0049
joem
joe
ohio
2015 j/k
can anyone list the dimensions of the under floor cubby storage area-i have a lockable toolbox out of my jk im planning on moving to my jl if it fits-thanks ps-i need approx 24x10x5 to make it fit
Lmchantres
Michigan
2018 Sahara JL
Wheels are same bolt pattern, BUT lug nuts are now metric 14mm x 1.50 where the JK has SAE 1/2 - 20.
Noob question, I have spacers off a JK...if I get open end M14x1.50 nuts to mount the spacer and 1/2-20 closed end bolts to mount the wheel to the spacer will it cause any issues?
Ape
Powell, Ohio
2020 JLU Rubi
I have the Magnaflow Performance Series Black axle-back dual-exhaust on my '15 JKU Rubi... will it fit on the JLU?
AZCrawl
AZ
2018 Granite Jeep JLUR
Unlikely, there were some significant exhaust changes on the JL. I am waiting for Magnaflow to develop this exhaust for the JL.
JLUSoCal
IT
AZCrawl
AZ
Thanks! Magnaflow's website is all screwy, so I couldn't find anything on there. I found an additonal 15% off here!
https://www.lmperformance.com/shop....=exhaust&type=exhaust-systems&sort=popularity
So, now I need to decide between the Rock Crawler or the Off-road Pro version. I know the Off Road version dumps before the axle. I don't want it to be too irritatingly loud. Does anyone have an experience running these on a JK to give your advice on which way to go? Both will serve the purpose that I am looking for, which is clearance.
cnyjl
Curt
Central New York
2018 Billet JLUR, 2019 Ram Rebel Crew, 2019 HD FLTRXS, 2018 HD FLFBS ANV
Kind of insignificant in the grand scheme of things, but would Just add mud hinge mirrors from the JK work on the JL? The type that you insert into the top hinge and a magnet against the opening frame holds it in place?
Bmartin220
Long Island, NY
2018 Wrangler unlimited JL
Factory rear hitch mounts the same JK to JL so in someone’s case where they didn’t add the towin package and had one laying around off a JK this would work. Was confirmed by Hauck Off-road on their Facebook video.
do you have link to video or Facebook page? Thank you
Gregodav
Wichita, KS
Rubicon 2014, Solstice 2007, 1993 GMC Pick-up
I. T. Director and Video Director
I am replacing my 2014 Rubicon with a JL Rubicon. I had upgraded the factory Rock rail with some need bar steps on my JK.
I was thinking about reinstalling my old factory rock rails on the JK and moving the nerf bar side step onto the new JL.
Does anyone know if the two models are compatible?
Martindfletcher
Martin
San Diego
Ducati 1299s, 2018 JLUR
