JK to JL compatibility listing
Rymar10
Ryan
Pennsylvania
2018 Jeep Wrangler Unlimited Sport JL
Budget boost upper spacers front and rear from a JK work on JL.
Rear lower coil spacers do not interchange.
Hello,
Do you have any idea if the JK running boards/side steps fit on the JL??
Thank you for your time,
Ryan
msujedi
Jed
Michigan
2018 JLU Sport S Firecracker Red, 2014 Durango, 1999 Honda CRV
Hello,
Running boards, side steps, rock rails, etc ... do not match from JK to JL. Bolt holes don't line up according to what I've read. There are several JL-specific options out there though.
Ethan
Ethan
Point Reyes Station
2018 Jeep Wrangler Rubicon JLU
Metal Fabricator & Stuff
Drive shaft interchangeability? I noticed that MetalCloak has the same part number for their 2012 and up JK front DS as their JL front DS. Does this mean the Teraflex JK high angle Rzeppa will work on the JL? I do have an old 2 door JK front DS, so I could check, but I'm too busy typing right now...
Inquiring minds want to know...
Ronyo2
ID
JKUR, XJ, Tahoe
Great thread !
Keep it a live.
Jrbrannan
Bloomington, Il
2018 JLUR Ocean Blue 2008 Highlander Hybrid (previously several CJ-7, YJ, TJ, JK)
I know the front bumpers work, I have a JK hard rock steel bumper on mine, what about the matching winch plate?
Paz141
Shane
Australia
Jk
Will the front quater panels of the JL fit the JK?
prdufresne
Paul
Ottawa, ON
2008 JKU Rubicon, 2019 JLU Rubicon (on order)
I was wondering about the wheels. I run 15" rims on my JK. They're a tight fit around the brake calipers, but they do fit. Are the JL brakes bigger?
I guess I'll have to test that out when I take delivery.
IronScott
NW Arkansas
2019 JLU Sahara, 1992 Jeep YJ, 2002 Chevy Silverado
Brakes are bigger on the Rubicon and Sahara. I don’t think you can run smaller than a 17” rim on either of them.
prdufresne
Paul
Ottawa, ON
Good to know. Thank you.
I'm also wondering if the e-brake is any better on the JL.
Biscuit
Northeast Ohio
2018 JLU Sport
Like any parking brake, it's adequate for restraining a stationary vehicle that's not running with the transmission in Park (auto) or in gear (manual).
Dito
Canada
2019 JLUR
Any chance a Spidertrax 1.5 inch wheel spacer from a JK will fit on a JL with the correct lug nuts?
kkuntz01
Mount Juliet, TN
2018 JLU Rubicon, 2014 Ram 2500 Crew Cab
If you’re looking at saving a buck because you can get a deal on JK spacers, pass and get ones already made for the JL.
If you already have a set for a JK, you could potentially make it work if you got the correct metric nuts to install the spacers on the axle along with a set of SAE lug nuts to go on the spidertrax wheel studs.
Truth is, whether you have a set or not, suck it up and buy the correct ones for you vehicle.
Steveo
Sitting on the lap of someone you love
'18 Wrangler JLUR, '23 F150 Rattler
Retired Code Monkey
How far off are we on the fit of a JK rear bumper? I don't see a post in this thread that discusses it. Anyone got a linky:whatsgoingon:
kkuntz01
Mount Juliet, TN
Not even in the same state. There’s no way to easily make a rear JK bumper on JL.
I had measured it at one time, but forget the exact numbers. The JK I think was around 46-47 (or something like) wide while the JL was more like 38-40 wide (or something like that).
RamMan
Frank
Oklahoma City
JLU Sport Dsl. / '16 Ram PW / '14 GC Dsl.
Transport / Odd Jobs
TPMS (tire pressure monitoring system) Sensors on a JL are the same part # as a 2010-18 JK
I had a '12JK. I put the '18 JL steel wheels on the '12 to sell that unit. Not compatible, the frequencies are different. Don't remember what year they changed. Your auto parts man will know.
