Jeep Antenna replacement
Noelnoly13
Noel
miami,fL
JL wrangler 2 door rubicon
i have a jeep JL and I like to listen to the fm radio on my way to work, I notice than in some areas I get no reception. is there a better antenna that boost reception that can replace the stock one?
[DELETED USER 82058]
Alabama
2022 JL Rubicon 2-Door
This is no help. Honestly most people ditch the stock for worse reception. Not sure there is a better option.
Rhinebeck01
Ormond Beach, Florida
Retired at 55 ..
You can move from the factory installed antenna to an aftermarket antenna but doing so only nets you even worse reception.
JJ_WA
JJ
Puget Sound, WA state
2002 Dakota, 2017 Cherokee, 2023 Willys XR
Retired US Army, Higher Education
I like listening to some AM/FM radio and have looked at an antenna like this https://www.theantennasource.com/JEEP/Wrangler/Wrangler-2007-2020.html#1A. They are similar to the OEM one I have my Dakota, which has very good reception.
That said, only a few of their Wrangler-compatible antennas indicate they gave "unmatched reception." There are no specifications indicating dB gain/loss for any of their antennas. Shorter antennas have more limited reception range than longer antennas (wave length). So, YMMV.
As @Rhinebeck01 says, moving to an aftermarket antenna nets worse reception.
Heimkehr
Pennsylvania
2021 JLU 2.0T
It's understood that the stock antenna, whippy thought it may be, provides the best reception. If there was one with comparatively better performance, particularly if it was shorter than the stock fitment, it'd be known to forum membership here. ?
hoch
Hoch
UT
2018 JLUR 6-sp
The stations I listen to also have a simultaneous streaming app. (ie, NPR).
Could that be an option for you?
Dlit
South Florida
Rubicon JL Recon
Not sure this will help but it is a YouTube vid on using a stock ford antenna…looks better for sure and I would guess would outperform the stubbier shorter options out there.
TX_Ovrlnd
CStat, TX
'22 Zilver JLURD
freethinker
A 6 minute video to talk about and install an OEM antenna lol. Content creation life is rough.
Badbear0416
Sean
Belle River Ontario Canada
2014 Wrangler Sahara Unlimited
Hey there...so I have also tried several aftermarket antennas and highly reviewed ones yet not a single one was better than the factory one unfortunately. I'm not far from big city stations and surprisingly the factory picks up way more and great reception. I did this on new 2023 rubi and also for my ram truck...both vehicles reception was way worse even with the best rated and several brands I've tested and returned them all and went back to factory.
Wbino
NJ
Huge ball of aluminum foil on top of antenna. ??
