It was a nice day today
Jeep Junkie
Jeep Junkie
Muhammad
Seattle, WA
2024 JL Wrangler Willys
Maybe just jack up the front and spin one tire? If the other rotates in the opposite direction then it's not locked.
So I will lock the front, drive over the lift, lift the Jeep, and rotate one tire and if locker is working both tires should rotate, correct?
Ratbert
PNW
2022 AEV JL370 JLURD
Software Engineer
In the same direction if locked. Opposite if not.
Jeep Junkie
Jeep Junkie
Muhammad
Seattle, WA
Jeep needs to be in drive so I will need a helper. The self serve garage owner is nice, he even said he will guide me on transmission fluid change
Ratbert
PNW
Software Engineer
Why would the Jeep need to be in drive?
Ratbert
PNW
Software Engineer
So it will work in Park?
If you're in park with "lockers engaged" and turning one wheel causes the other to rotate in the opposite direction then your lockers are not engaged.
Pape
Quebec
JLU Sahara
You can just jack the front end in 2WD and all 3 shafts should be spinning, both wheels and the drive.
Do you have a FAD still ?
Jeep Junkie
Jeep Junkie
Muhammad
Seattle, WA
Not sure. Next week I will go to the self serve garage and test my locker
