Issue after adding LED DRL
LHuffman47
Lucas
Glendale
2018 JL Sahara
Automotive Sales Manager
Hey guys, so I added LED DRLs to my Sahara. I bought some factory take offs. I installed them, and used jscan to activate them. They function perfectly, the only issue I have is that I have a constant “Turn Signal Lights Out” message.
Has anyone else experienced this, also if anyone has any recommendations to remedy that. Please let me know!
thanks!
hoag4147
Colleyville, TX
2022 JLUR XR
thanks!
You may want to reach out to @Gregj. He is pretty knowledgeable of the jscan app. Great guy and always seems willing to assist.
LHuffman47
LHuffman47
Lucas
Glendale
2018 JL Sahara
Thanks I’ll reach out to him. These are my current codes, and current drl settings
Jeep Wrangler JL Issue after adding LED DRL 0AFE20F1-EBC3-492E-A93E-43E978828977
Gregj
Greg
West Texas
Replyed to your pm. The LED turn signals don’t draw enough current so the BCM thinks they are out. Change the settings for LED turn signals here and that should fix it.
Jeep Wrangler JL Issue after adding LED DRL CD75F83C-1CF3-4278-ACDA-5E265D996367
Jeep Wrangler JL Issue after adding LED DRL FC7E72C9-7950-4E11-848F-645ABE18C6E3
Gregj
hoag4147
Colleyville, TX
2022 JLUR XR
Gregj
You dah man Greg :like:
LHuffman47
LHuffman47
Lucas
Glendale
2018 JL Sahara
Thanks Rick! Hope my suggestions help @LHuffman47
Gregj
So, I have updated everything to reflect properly. I have also turned off front turn light diagnostics.
When I reset all ECU’s, the code will not populate for about 15-20 minutes, at that point the turn signal lights out message appears again.
Another thing I have thought about changing is the light draw settings, has anyone done this to any success?
Gregj
Greg
West Texas
Have you tried disconnecting the battery or batteries (no clue which drivetrain you have)?
Gregj
LHuffman47
LHuffman47
Lucas
Glendale
2018 JL Sahara
Gregj
Haven’t done that yet, have 3.6 w ESS
Gregj
Greg
West Texas
I would try that as it has been known to cure all kinds of odd issues.
Gregj
LHuffman47
LHuffman47
Lucas
Glendale
2018 JL Sahara
LHuffman47
LHuffman47
Lucas
Glendale
2018 JL Sahara
Disconnected the battery, code cleared for about 15 Minutes and re appeared.
Gregj
Gregj
Greg
West Texas
Wow, I’m running out of suggestions. Very strange issue. Curious, which OBD2 are you using?
Gregj
LHuffman47
LHuffman47
Lucas
Glendale
2018 JL Sahara
Gregj
Icar gate 4.0
Something I was thinking, when I switched out the DRLs the factory led turn signal was retained. The ones that came with the takeoffs were scuffed. I inspected them and they appeared to be identical.
Gregj
Greg
West Texas
That’s the OBD that I use so that’s not the problem. That amber side marker is led and is the same for all models so I don’t think that is the issue.
Gregj
