Is this so simple?
TordFuglstad
Tord
Norway
Jeep JL 2.2D
Hi there!
Is this simply the wheel bearing? Or could it be something more serious? It's a Jeep JLU with Dana 44 narrow and LSD. No lift.
Video here:
Phrank
NEPA
2018 JLUS
Sure looks like a wheel bearing to me. Once you get that much up/down play, they usually go completely T.U. pretty quickly.
Lofty
Casey
Ohio
JL Wrangler
Is the bearing making adverse noise while driving? Those wheel ends are supposed to have endplay as you have shown in your video.
Pape
Quebec
JLU Sahara
You replace the whole wheel hub assembly. It is an easy job. Takes about an hour.
Unless the retaining assembly spin on it self than you need a welder. As it look to be the back axle not the front with hub bearing unit
TordFuglstad
TordFuglstad
Tord
Norway
Jeep JL 2.2D
What do you mean exactly?
TordFuglstad
TordFuglstad
Tord
Norway
Jeep JL 2.2D
There's no noise. Might be some clunk while over very sharp speedbumps. But not sure if it's related to this.
Pape
Quebec
JLU Sahara
the retaining bolt are press fit and if like the JK, they have a tendency to start spinning when you try to remove the nut on the back side. only way to get it to stop spinning is welding them to the retainer.
Also if you go down that road do your self a favor and weld the new one in place so next time is a simple as just removing the nuts :)
Depending how much money you want to throw at it, you can get the full assembly that you just need to slide in and bolt. If the bearing race does not stay in the axle tube and you need to "fish it out", that is.
Jeep Wrangler JL Is this so simple? 1741193107319-nr
Lofty
Casey
Ohio
JL Wrangler
If it's not making bad noise, I'd leave it alone!
wibornz
Ted
lansing, Mi.
JL Unlimited Rubicon
Did not notice that it was the rear tire. Still an easy fix. I can be a little more complicated as you said, but that is a newer Jeep and does not look like this has been abused in the mud so it will probably come apart pretty easy. I find that if it is difficult to get the axle out. I put the rotor back on the wheel studs backward and only put the lug nuts on a couple threads so I can use the rotor like a slide hammer to remove the axle.
Phrank
NEPA
2018 JLUS
BRILLIANT!
TordFuglstad
TordFuglstad
Tord
Norway
Jeep JL 2.2D
Thank you all for your insights and replies! Do you think replacing the axle shafts to chromoly shafts is a good fix?
I guess it would also offer a significant upgrade over stock.
I do have a Sahara with Dana 44 Narrow SelecTrac.
mwilk012
2018 Ocean Blue JLU Rubicon
Service
What makes you think there’s something wrong with it?
TordFuglstad
TordFuglstad
Tord
Norway
Jeep JL 2.2D
Clunking noise and the fact that I can move the wheel on this side, but not the other size. A big difference. You think nothings wrong?
mwilk012
Service
It doesn’t sound like the wheel bearing is the source of the slack, but that could be a cell phone audio issue. The noise is very sharp. What drove you to lift up the rear wheels and shake them?
