Is slight rod knock on cold start normal?
Mkz567
Somewhere
2026 Wrangler Rubicon X 2.0
Business owner
Does your 392 make rod knock noise on cold start? This normal
Only has 3500 miles.
Bandit59
Tennessee
2021 Jeep Wrangler 4xe
I have a 5.7Ram that makes noise on start sometimes. It’s a lifter noise for about 2-3 seconds
WantToWander
Austin
2023 Rubicon 392
Mine has ~30k miles now. I get the squeaky noise, but not the knock. It might be fine, but I'd take it to the dealer just to get it on record in case it turns into a bigger thing later (post warranty).
Bayrat
DA
NY and Fl
2023 Rubicon 392 - 2024 Gladiator Sport BAREBONES
Mine makes that same tick which subsides almost immediately. I've had many engines which made that same noise until the oil reached all of the components.
RubiconJL392
Newberg, OR
2022 Jeep Rubicon Unlimited 392
Ya, my 05 jeep 4.0 6 did the same thing.
azjl#3
North AZ
Don't think thats a rod, you would really know it. More like lifter/valvtrain something. Sort of normal these days.
Try a can of lucas viscosity modifier. Made mine quite.
Bandit59
Tennessee
If it was a rod knock it would be loud. And mostly all the time. You probably have a lifter noise till oil pressure builds up. Many do this. Mine does but not every cold start
Aquastream
Andrew
Alberta
2021 JLR, Hella Yella, 2.0 T
Sounds like what happened to my 2017 ram 5.7L. Believe it was a cracked manifold or cracked manifold bolt. Should be warranty. Do some reading online on exhaust manifolds on Hemis to arm yourself when you go back to the dealer
Mkz567
Somewhere
Business owner
Here is another cold start after 4 days sitting. You guys sounds same?
azjl#3
North AZ
I think thats just lifters oiling up, not rod knock.
To help the lifters, try a can of lucas low viscosity modifier, it stops the lifter tick.
This is rod knock
