AC not cold when Stationary?
supermike
mike
Irvine CA
18 JLUR 6 speed 2021 JLUR 392
Since day 1 I felt the AC was not as cold as my 2018 JL. Today I was waiting for my gf and sitting at the parking lot and definitely felt the AC was just cool, not cold at all. I have ceramic window film all around including windshield, sitting under the sun at only 85 Fahrenheit, MAX AC wouldn’t even cool the cabin???
Rico1111
Rico
RI
2018 Rubicon 2 door JL
Make sure the recirculation button is on also! It helps a lot ...
supermike
supermike
mike
Irvine CA
Yes it’s recirculating I’m just trying to see if this is a 392 specific issue due to large amount of heat generated and lack of air flow at stationary…dealer is busy and my experience with FCA dealer is they usually creates more problem…
Dan M.
Albany NY
2020 sport (2 door)
If it works better when moving at a decent speed. Could be a coolant leak or something.
Rangemaster
Nevada
2020 JL Rubicon Diesel
Business Owner
I have the same issue in my eco-diesel also. When your moving it works great, stopped and its just cool.
Rob97RR
Rob
Northern 'burbs' Chicago, IL
22 392 XR Rubi, 2023 C8 Corvette Z06 & 2023 Ducati
Stay at home dad to 2 munchkins, best job in the world!
Same. I guess mine's not terrible when parked, but it's definitely colder when moving.
SLORubi
Stephen
Grand Rapids, MI
2018 JLUR; 2019 A4 S-line
It’s not a 392 problem. AC units need air moving over the condenser to work, more air flow = more heat exchanged = cooler air output. Plus at low RPM the system is not moving the refrigerant as much. Add them together and you have a system that can’t keep up with the high outside temps.
You can try increasing RPM to see if the extra refrigerant circulation helps. Just a test, sitting at a red light or a parking lot revving your 392 is gonna send a different message.
supermike
supermike
mike
Irvine CA
I totally agree with you. While my 3.6 is freezing cold at idle under the sun at 100 F. Just wondering if’s a 392/diesel thing.
Marine2146
North Carolina
2023 Grand Wagoneer 3 series, 2022 Rubicon 392
You could use the high idle “winch mode” feature of the tazer mini if your going to be parked often.
SSWIM
Sam
Too Many
The newer ac units work well sitting still. The condenser/radiator fan pulls plenty of air. More so than ram air. I have 2 AC repair facilities. Yes it is more efficient at highway speeds like you referred, but still more than capable at idle.
My 392 works very well at idle. On a hot, 95+ day after sitting in the sun it cools down quickly and has no problem keeping the interior cool.
Mike, get yours checked. Something wrong with it. Mine works every bit as well as my 20 JL 2.0 did which was way good also.
Sam
