I have a 5.7Ram that makes noise on start sometimes. It’s a lifter noise for about 2-3 secondsDoes your 392 make rod knock noise on cold start? This normal
Only has 3500 miles.
Yes. As long as it doesn't continue.Does your 392 make rod knock noise on cold start? This normal
Ya, my 05 jeep 4.0 6 did the same thing.Mine makes that same tick which subsides almost immediately. I've had many engines which made that same noise until the oil reached all of the components.
If it was a rod knock it would be loud. And mostly all the time. You probably have a lifter noise till oil pressure builds up. Many do this. Mine does but not every cold startDoes your 392 make rod knock noise on cold start? This normal
I think thats just lifters oiling up, not rod knock.Here is another cold start after 4 days sitting. You guys sounds same?
