Jeep Junkie
- Muhammad
- Dec 7, 2024
- Seattle, WA
- 2024 JL Wrangler Willys
Thank you. So that level is good when coolant is 217?Look good to me, my level stand little above or under the central line of the reservoir.
As for temperature you are 16 F away from the fan kicking in if you are at a stop.
at 217 this is ok for me but limit. I would love the fan kick in at that temperature but from observation will only kick in at 233....Thank you. So that level is good when coolant is 217?
What if I add a tiny bit of coolant to the reservoir?at 217 this is ok for me but limit. I would love the fan kick in at that temperature but from observation will only kick in at 233....
No issue until you read the full. I Would not expect much from doing that.What if I add a tiny bit of coolant to the reservoir?
Thank you, then I will just relax. But I will keep an eye on itNo issue until you read the full. I Would not expect much from doing that.
Wow, I'm low. How can I add, remove the cap of the reservoir and then just pour some? Thank youOP, I’d add a little to the reservoir and keep an eye on it. Mine cold:
Yes, remove cap when cool and add OAT coolant.Wow, I'm low. How can I add, remove the cap of the reservoir and then just pour some? Thank you
Can I buy some aftermarket one from AutoZone?Yes, remove cap when cool and add OAT coolant.![]()
Absolutely yes.Can I buy some aftermarket one from AutoZone?
