Ironman Tires
JLSpiker
Uniontown, PA
2021 Wrangler JLU
So I was scrolling through the WalMart app yesterday, looking at tires. I came across the Ironman All Country M/T LT 37 12.50 R20 for 105.20 each!! I immediately ordered 4! 4 37 12.50’ for $420.00!! A bit later I had an epiphany that I needed 5 tires so I had one for my spare, I went in to get another and lo and behold they are now $315.00?.
Anyone interested in 37’s may want to take a look on the WalMart app for this deal, it might be active somewhere.
Jeep Wrangler JL Ironman Tires IMG_0092
AcesandEights
Aces
So. Oregon
2024 Toyota 4Runner
Is that an "F" load rating? Wow, that ought to be stiff!
TrailScooter
'20 Jeep JTR, 91 F1504x4 and so on...
Wuck falmart!!!!!
I couldn't go there anyway. I passed the IQ test and dress too normally.
JLSpiker
JLSpiker
Uniontown, PA
2021 Wrangler JLU
Yes it’s an F load rating,. I know it’s gonna be a little stiff, but I needed another set of wheels/tires to run in the winter so I don’t ruin the Fuel wheels/Nitto tires. I found a decent set of 5 20x10 rims on FB Marketplace so I should be all set!
Camaroboi13
Justin
San Bernardino, CA
2022 JTOD, 2024 JLU W
LEO... life in Chino
I have those on my JTOD in 37x12.50r17
the grip is amazing and they’re not as firm as you’d think. After 26k miles they’re about halfway worn down, but I do keep 36-38 psi in them as I drive 72 miles round trip to work every day and want to maximize mileage. I like the tires but they do get pretty noisy once broken in and one of my tires is now so out of round that it needs replacing. You will also feel every single lug on the tire when coming to a stop. I’ll be switching to a different brand sooner than I wanted to.
JLSpiker
JLSpiker
Uniontown, PA
2021 Wrangler JLU
Thanks for the info!! They should be perfect to get me through 4/5 months of winter driving.
Ratbert
PNW
2022 AEV JL370 JLURD
Software Engineer
20s with an F load rating? Yeah, they'll be "a little stiff".
Camaroboi13
Justin
San Bernardino, CA
They will do just fine for your winters. Have a tire shop with a brain install them, otherwise you’ll end up with about 5lbs of weights on one side of the tire instead of the guy just rotating the tire to find the light spot. Happened to me the first time around smh
Jeep Wrangler JL Ironman Tires IMG_2723
I needed to be at work in an hour and rushed it. I took it back to a reputable shop the next day and they were able to make it right
JLSpiker
JLSpiker
Uniontown, PA
2021 Wrangler JLU
Thanks for the info! It’s amazing what a difference the right shop makes on something as common as tire mounting and balancing.
AcesandEights
Aces
So. Oregon
2024 Toyota 4Runner
20" wheels, and an F rating, should be stiff, and slick in wet weather!
Da Capt
PJ
Nyc
2017 JK sport
Those tires are pretty good I never had an issue with them. Some people believe if u don’t spend 1500 bucks on tired that they are crap. If u have a budget u can’t go wrong
Ratbert
PNW
Software Engineer
It all depends on what you're looking for. "Pretty good" is significantly different for someone looking for a set of tires that will last years and years with very little wear versus someone that needs top snow or rain or mud or rock crawling or quiet or comfort or handling characteristics. And, of course, for some people cost is the most important characteristic.
AcesandEights
Aces
So. Oregon
2024 Toyota 4Runner
Exactly. Those look like a low-priced tire that will provide very poor wet weather traction. They'll probably wear like iron though. If you needed tires for a few months (4-5 months), specifically for a purpose (wet weather traction), that's the opposite of what I would buy.
You're buying a medium-duty truck tire, one that will have a wear-like-iron body and very little siping. They'd probably be good on a full-size F350 used to haul or tow heavy though.
Camaroboi13
Justin
San Bernardino, CA
They actually do better in the rain than most tires I’ve owned. Yeah, I was surprised too.
