Badunit
I am having an intermittent blower motor problem on my JT where about half the time when I start my truck it is stuck on fan speed 1 and the fan speed knob has no effect. Other times it works perfectly fine. It is a toss up which it will be when I start my truck but, whichever it chooses, it stays that way until I start it again. I'm at a loss as to what the problem could be. I hope someone here can help.
I have an Icon T10 and have done the following diagnostics:
- Read codes. There are none.
- Watched live data of the blower control knob, blower speed, and blower PWM as I turned the fan knob. The knob position is recognized regardless of whether the blower reacts to it or not. The knob position is also displayed on the UConnect and it, too, recognizes it. The blower speed and PWM remain static (equivalent to level 1) when it is not working correctly. They go up and down as they should when it is working correctly.
- Controlled the fan speed knob though the T10. The blower speed changes if I set the knob position in the T10. After cancelling the control, the actual knob still does not work.
- Controlled the fan speed though the T10. The blower speed changes correctly when I control it through the T10. After canceling the control, it goes back to fan speed 1 and the actual knob still does not work.
