ntravaglino
- Nick
- Mar 14, 2021
- Charlotte, North Carolina
- 2021 JLUR 4xe
Hey guys, thought I'd share an interesting behavior of the hybrid system after getting it back up-and-running properly. I'd be interested if anyone else has experienced this.
For starters, I encountered the FORM and CCOH errors that so many others have run into. I took delivery in April 2021, and the problem started in February 2022 at about 6000 miles. Service identified "7275 hightemp coolant pump failure" with code P0c74-00. After waiting for the part to arrive it was installed and the hyrbid system has been generally working well. The car starts up in electric mode and uses up the battery in hybrid mode until around 50% battery life is left or unless I mash the pedal. Then the ICE and electric motors alternate. This is consistent with operation prior to the first FORM/CCOH errors.
I drive the 4xe to/from work 26/33 miles each way most days. In the mornings the trip is shorter and slower (this is important). On the way home I take the highway and speeds are more like 70-75 MPH. This is where the interesting behavior comes in: On the way home, at highway speeds the electric motor operates from 100% to 30%. Then once I dip below 30% battery life, while under steady throttle, car speed declines to sub-60 MPH. and will maintain there until I mash the throttle or manually switch to e-Save from Hybrid mode. I can best describe the throttle response as being like a speed limiter/governer kicking in. I can usually get back into hybrid mode after a few minutes so it is no big deal, but it is different from prior behavior. Anyone else experiencing this?
