Intercooler(CAC) temps
ALeeL
Anthony
2021 JLURD
Can anyone who has the ability to look at intercooler/charge air cooler temps tell me what they normally see. I finally started looking at mine and they are really hot compared to what I see with my other diesels. They easily got up over 200F driving normally with ambient air being 73F. Most of my other diesels stay within 20F of ambient.
Looking at the location of the intercooler, it is not out front like my other diesels and is tucked behind the trans cooler. This is a very stupid place to put an intercooler. Just wondering if this is normal or I may have a boost leak or restriction problem.
AC77
AC Abegian
Los Angeles
Autobody , singer-songwriter
It’s behind the condenser and it pretty large from top to bottom and side to side 200f is normal on these engines
I installed larger pipes from age and have wrapped the pipes with heat wraps I will be wrapping the downpipe as well as much as I have access to
ALeeL
ALeeL
Anthony
2021 JLURD
Thanks! I think I may have found the issue. My torque app only picks up one sensor and apparently there are two. Started watching all the available sensors through Jscan and it picked up another. Likely one is pre intercooler and the other one is after intercooler. The post sensor never got past 20F ambient. This makes me feel a lot better.
Jeep Wrangler JL Intercooler(CAC) temps 1000013470
BDinTX
Dallas, Tx
I added those PIDS to my iDash and was seeing similar to what you showed. ~70° ambient, about +15°-20° on sensor2, and about 2x - 2.5x on sensor 1
SLK RCK
Jamestown, RI
2020 JLUR
Any chance you have a link for those PIDS? I couldn't find them....
BDinTX
Dallas, Tx
On iDash they’re all under the temperature category:
Jeep Wrangler JL Intercooler(CAC) temps 1731183557260-5
AC77
AC Abegian
Los Angeles
I dash shows these 2 readings ? Under what abbreviation ?
BDinTX
Dallas, Tx
ya unless I’m misunderstanding. It’s in the image I pasted in above.
AAT Ambient Air Temp
CAC1/1 CAC temp bank 1 sensor 1
CAC1/2 CAC temp bank 1 sensor 2
AC77
AC Abegian
Los Angeles
I’m a bit confused but believe you. I have a derringer tuner with the gauge it came with Is there another idash?
Mine doesn’t have pages like this. But I’ll take another look
BDinTX
Dallas, Tx
Ohhh I think I’m following- that image is from their PIDs documentation on the web. The iDash shows the first bit when you’re monitoring them:
AAT
CAC1/1
CAC1/2
