bmpcamry09
- Brad
- Feb 13, 2026
- New Athens, IL
- 2025 JLU Sport S 3.6 8AT
I’ve talked about this in my other threads, but I want to start a fresh one as those are super crowded. This is in an effort to educate people and make the JL community more aware of what I believe is the root issue
I’d like opinions on what people think is causing this. Is it materials? Design? Tuning? A combo of all 3?
I think it could be all 3, with tuning and design at the top of the list
Cam failure…..EVERYONE keeps talking about it. Everyone gets it fixed. Then they all fail again. Something I find unique is on nearly every failure people post about, there is a common theme: the failure is on the intake cam, and the cam damage is on the center cam lobes.
Some people make it 150,000 plus without issue. Some people make it 5000 miles.
This is different than the cam/lifter wear on the first gen 3.6 from the JK days. I mean, yes, crap materials, but I’m not convinced the PUG pentastar 3.6 failures are only from crap materials.
If you guys look into the Variable Valve Lift system on these PUG 3.6 engines (2018 and newer) and look at its design and use, you’ll see why these could be having so many cam and lifter failures. At least, this is my take on it. Mind you I’ve probably done more research and study on this than the average Joe.
Almost every camshaft/lifter failure I have seen on these newer engines post 2018 is the center lobe (high lift) and not the two outer lobes (low lift). The two smaller outer lobes of the cam shaft are what are used 80 percent of the time the engine is running. Most of the damages on these newer engines are the big center lobe/high lift lobe.
The high lift side doesn’t use a traditional roller/rocker. It uses a pin and its engagement is a very abrupt event. Ironically, when I developed tuning on these I actually discovered that “high lift” mode isn’t even used for high power and that high lift is used more like a way to add airflow for emissions purposes at lower load. Think of the engagement points as being very similar to when Eco/MDS/V4 mode kicks in on the hemis and GM V8 engines. The people who have been saying for years high lift kicks in over 2800 RPM are straight up wrong.
I made a whole video about this debacle, and I am confident this hi lift system is partially causing premature cam wear, in addition to less than quality materials.
You’ll probably never see a formal fix from Jeep in the USA for this because it will effect emissions and they won’t jump through the hoops for that, even though everyone running my fix for this is reporting same or even better MPG.
I don’t have any long term proof yet guys that this is the issue. But with all the years I’ve been messing around with these engines and the amount of research and looking into them I’ve done, it just makes sense to me. These advanced emissions management systems hurt more things than do good across all manufacturers.
