Instrument panel cluster?
TrailJoy
Northern BC, Canada
2020 JLUS, HellaYella
I’m reading the manual but I can’t find the answer.
1. Is there a way to reorganize the favourites menu?
2. I changed the left/center/right (center set to time) but when I restart the Jeep it defaults back. Is there a trick to changing it permanently?
grady2hig
Wisconsin
2018 Rubicon JLU, 2017 Toyota Sienna XLE 4WD
It should just stay...
Gregj
Greg
West Texas
Gradu2hig is right, those changes should be “permanent “. A trip to the dealership is in your future. For grins make sure all the fuses are fully seated, it might help as it has for other mysterious issues. Check fuse 22, 23, 34 and 41.
hth
Gregj
Shooting or Jeeping
2020 JLUR, 2019 RAV4
As the other two posters mentioned- it should stay. I changed mine a couple times and even disconnected the battery at some point. Stays the same. I would make sure you aren’t in motion and the car is running. Then see if they save.
TrailJoy
TrailJoy
Northern BC, Canada
It definitely does not stay. I tried it again today to make sure I wasn't missing anything. It resets back when I restart the Jeep.
Another thing that it does(n't do anymore) is the talk button on the steering wheel. I used to be able to hit it and say "text, soandso" and it would allow me to send a text message by voice. Ditto for the call button. It will allow me to answer a call, but not to send one.
Also not normal?
TrailJoy
TrailJoy
Northern BC, Canada
The first time I changed it the car was not running. The second (third, fourth, fifth) the car was running. The first time in park, once at a stop light (ESS engaged). Does not stay. I'll look into it... thanks, all!
