I don’t see the difference
Logan-Kn
Logan
Carson City, Nevada
18 JLU Rubicon
Hey all, I’m shopping for 35” wheels for my rubi and I came across these on tire rack.
https://m.tirerack.com/tires/tires....SR7KO2V3&vehicleSearch=false&fromCompare1=yes
And these
https://m.tirerack.com/tires/tires....17TR7KO2&vehicleSearch=false&fromCompare1=yes
One says it’s Jeep and the other Ford performance. Both are load range c
I want to go with the cheaper of the two but I’m not sure if there is any difference between them. Maybe someone can clear up the confusion for me on this one?
gerlbaum
Greg
Arizona
2021 Wrangle Sport Diesel
Edited because I was wrong. Both tires have the same max load rating of 2535. It’s the speed rating that is different. One is 113/110s the other is 113/110t. One is rated to 112mph the other is 118mph. Discount will only mount like for like load indexes set by the manufacturer (the first number 113). They no longer care about the load rating. I’m not sure if they care about the speed rating (the second number).
Logan-Kn
Logan-Kn
Logan
Carson City, Nevada
18 JLU Rubicon
Ok, luckily I actually work at a dealership so I can mount whatever the heck I want. Will I see any negative effects toward my Jeep off-roading with these other tires?
gerlbaum
Greg
Arizona
That I don’t know. Hopefully someone can chime in.
Logan-Kn
Logan-Kn
Logan
Carson City, Nevada
18 JLU Rubicon
I’m really interested in these cause it’s nearly a 200$ difference in the end when buying 5
turbosix
dallas
2019 JL Rubicon
The easy answer to your question is..
If you have to ask then no, there is no difference.
