TJ&JL
[MEDIA
the allen screw clockwise a little less than 1/8 a turn. The factory marked the nut,allen screw and box with paint so it's easy to see how far you turned it. Then tighten the nut.
I broke the nut loose using a socket,backed it off half a turn. The allen screw will move with it. I then held the nut steady with a wrench , used a Hex socket with extensions and turnedThanks! I watched the videos before (they are for the JK, but same adjustment of course). How did you hold the allen wrench in place if you used a socket? The video shows to use an open ended wrench so you can use an allen wrench to hold it in place, then adjust 1/8 of a turn, then re-tighten the the nut while holding the allen wrench at the 1/8 turn point.
