How to delete code
quicksilver
Arthur
MA
2018 JL sport
I added a cut off switch by switching off the fuel pump. If try and start the JL with the switch off you get a check engine light. The jeep shows codes for low voltage to the fuel pump which is correct. I can reset the check engine light with my cheap code reader but can not erase if from the memory. Anu suggestions?
