How do the factory lockers operate
JLyfe
Anthony
SF bay area
JLU
I’ve been trying to search on how the front or rear elockers work. Not in reference to the switch on how to turn them off and on, but how the whole elocker mechanism works. If someone can point me in the right direction with resources I would greatly appreciate it.
GATORB8
CLT NC
21 JLURe, 06 LJ, 25 HDZR2
There a YouTube tear down, but IIRC, a spring holds a toothed gear off the case, and an electromagnet engages it.
I’ll try to find it for you.
JLyfe
Anthony
SF bay area
JLU
So if one is inoperable it’s likely the electromagnetic mechanism that engages and disengages? Has anyone had any issues with the carrier itself?
GATORB8
CLT NC
You are actually having an issue? What are the symptoms?
JLyfe
Anthony
SF bay area
JLU
I bought a rubicon axle with an “inoperative locker” and I’m trying to diagnose it. The electromagnetic plunger was separated, but the carrier looks fine. I am trying to understand how the carrier works in order to see if it is still operational.
GATORB8
CLT NC
I think @chevymitchell is the resident expert.
chevymitchell
Shawn
Pueblo West, CO
Avi Engineer
The large magnet energizes with magic.
Then the magnet pushes the locker plate assembly down with said magic. The position of the plate is what determines if the dash shows lock or unlock.
The plate then pushes on 5 pawls. These 5 pawls lock the spider gears together, thus removing the open diff option. Once this happens, then both axle shafts must turn with the ring gear.
Pawls shown below. The inner plate mounts to the "U" shapes you see. Then this inner plate spins inside the outer plate. The magnet pushes both plates into the carrier housing locking the spiders together.
Jeep Wrangler JL How do the factory lockers operate 1675196228130
JLyfe
Anthony
SF bay area
JLU
Thank you,
Does anyone have a blow out diagram of the internals of the carrier?
JLyfe
Anthony
SF bay area
JLU
by the looks of my carrier it does seem as if the internals are broken due to all prongs not protruding evenly.
Jeep Wrangler JL How do the factory lockers operate A47DC1EB-C94E-46DD-9E6B-342D83F14ED8
chevymitchell
Shawn
Pueblo West, CO
Avi Engineer
Yeah, if those don't push down and spring back up, then it's jacked up.
I haven't seen any factory 220 locker carrier parts available. I've only seen diagrams and parts for the open diffs and LSD's.
GATORB8
CLT NC
Checked my AllData account. It has the LSD overhaul in the section for the locker, and no additional internal parts list, everything on the locker parts wise is listed as part of assembly.
1996cc
Oregon
22 JLUR 392
@chevymitchell any idea why the main cross pin is drilled in the center with another small pin inside of it. This is my destroyed rear locker, I tore into it trying to diagnose what happened. You can see the pin is broken, but that’s right were it was drilled and I assume had a smaller pin in it??
Jeep Wrangler JL How do the factory lockers operate A15A1E4F-5BDD-4B75-BF61-B0CFE5317138
JLyfe
Anthony
SF bay area
JLU
The cross pins look thin.
chevymitchell
Shawn
Pueblo West, CO
Avi Engineer
I don't think there would have been a pin in there. I also can't think of why there would be a hole in it. I'd need to take one apart and look at it. This picture is tough to make a determination. Off the top of my head, I don't have any good answer to your question. I'll keep it in mind though.
