Bril
- Bill TxRedRubi
- May 22, 2018
- Central TX
- 2022 Rubicon 392, 2024 JL Rubicon
- Vehicle Showcase
- 1
Thanks BennyHi Bill,
Im afraid the latch is not serviced separate from the glove box itself. A new glove box assembly can be found here
https://parts.allmoparparts.com/oem-parts/mopar-glove-box-6ab14tx7ad
You should be able to swap the cylinder over as this is a serviceable item.
One thing we can check before ordering is if you can remove the remainder of the latch from the glove box door we can check for stamping numbers on the back of it.
-Benny
That's what I was afraid of looking at the design. I will pull it apart and see if I can find a stamping on the back and if the lock cylinder is removable.
