How Can We Help?
AllMoparParts.com
AllMoparParts.com
Peak Sponsor (Level 2)
Benny
NY
2018 JL
hey Benny!
is there any fan from Mopar that has a higher CFM than the 68272755AD ?
Hi,
We do not have CFM ratings unfortunately. The part number you have is applicable for towing packages so I do not think there is anything "better" however I did find a part # for use in "Middle East" equipment group but was also used here in the U.S in earlier years. The part # is 68340962AC , I found this guy selling one https://www.ebay.com/itm/276497816039
Looks like its labeled as 940 Watts? I couldnt find any good photos of 68272755AD to see what the wattage rating is. If you are able to check yours that would be good info.
- Benny
AllMoparParts.com
AllMoparParts.com
Benny
NY
2018 JL
Hi Benny, I hope you can help me out with finding this Christmas tree plastic clip. It holds the main harness wiring connector for the right front door disconnect on a 2024 Rubicon. It clips into the slot (circled) and pushes into the hole (arrow). For some reason, I don’t have one.
I am sorry but I do not see the clip being serviced. One quick solution to this is to trim a standard push in clip to slide into the channel. A kit like this should have one you can use https://www.amazon.com/GOOACC-Retainer-Retainers-Universal-Assortment/dp/B06XKV7JHJ/ref=sr_1_3?crid=1CGCQRW3BRN1V&dib=eyJ2IjoiMSJ9.Ct5IpCNNLp6lCqT8x6tELzFGLUwZbWSD3NQ0jWK2hR7heAIk0qBuYxdluB95U2wliJy5tFnG_ZmrVMaugIRgS99vNGxkQJxOphkTCmcPe0a7YTrw0d5yGVk_sQLKfoa2ssJtZssEuhWAVu1mVLypuiIUk0T7uzmqneR54QpVHVvGdkx84kVpsZgkFsR6dmvfgZmyk0yYkSHv02yJZzBIEx7alB2CJxJGQJNZ_Dk3u9c.LN3hACHD1vNbn6QgLUa7tXQ8QZwzNW_EMk_QRr_Gos4&dib_tag=se&keywords=tree+clip+automotive&qid=1759792859&sprefix=tree+clip+automotiv,aps,193&sr=8-3&th=1
- Benny
Dusty Dude
Colorado Springs, CO
zouch
Berkeley, CA
XJ, JLUWD
thanks for checking it out!
Hi,
- Benny
CWRUYOTE
CLE
2021 JLURD
Hi Benny!
Is Mopar 6843681AB the correct fuel filter cap for the JL 3.0L EcoDiesel, or do I have to get the entire housing (Mopar 68382328AC)?
Thank you in advance for your assistance!
Baidyk
SC
2022 Wrangler Rubicon 2-Door
Hi Benny,
Is it possible to buy just part of the Hardware Kit – Mopar (68413711AA) that’s used with the Spare Tire Carrier – Mopar (82215355AC)?
I’m specifically looking for the M8 Hex Bolt from this kit, but I can’t find any reliable information about the correct length it should be.
Do you happen to know the exact size?
Thanks in advance!
AllMoparParts.com
AllMoparParts.com
Benny
NY
2018 JL
AllMoparParts.com
AllMoparParts.com
Benny
NY
2018 JL
Hi Benny,
Thanks in advance!
Hi,
Yes we can get the kit. I am sorry but I do not see any specs on that bolt. If you have the rest of the parts you would be able to assess what length is required though.
https://parts.allmoparparts.com/oem...wJnk9MjAyMiZ0PWJpZy1ob3JuJmU9NS03bC12OC1nYXM=
Please let me know if you have any other questions,
- Benny
23xtreme35s
Richard
Des Plaines, IL
2023 JLU
hi benny,
I bought a rubicon hood shell for my willys. I need the vents and the liner for underneath. and anything else that will not transfer over. part numbers so I could order.
thanks
Richard
AllMoparParts.com
AllMoparParts.com
Benny
NY
2018 JL
hi benny,
thanks
Richard
Hi Richard,
We would not want to ship the hood liner as it will most likely get creased. If we box it strong enough to survive UPS then it becomes too expensive to ship, We suggest picking this up locally.
The vents are
https://parts.allmoparparts.com/oem...eft-68293749af?c=bD0xJm49U2VhcmNoIFJlc3VsdHM=
https://parts.allmoparparts.com/oem...ght-68293748af?c=bD0xJm49U2VhcmNoIFJlc3VsdHM=
The hood pad part # you need is 68292168AE
Im not really sure what else to suggest, Push pins for the liner are 6504135
Are all the rubber seals intact? Do you need latches?
Please let me know if you have any other questions.
Thank you,
- Benny
apensity
Chico, CA
2024 4xe Sport
Benny, thanks for all you do! I have a 2024 4xe Sport S (with the M220 WT rear and M210 WT front) and was wanting to install regular OEM e-lockers in the (currently) open diffs. Are they a bolt in using the existing axle shafts? Or is there an offset in the carrier which forces me to use different length axles? Thanks for any info!!
Texas Longhorn
West Texas
2025 Mojito Sport S
Retired, with a good income.
Hi Benny, I’m looking for the Mopar fuel filter door, part # 82215123AB. Dealer quoted me $211 and stated it’s a special order part no return. Hoping for a better deal, but wonder why it‘s considered special order. Part for a 2025 JL Sport-S
rowbarre
Boise, ID
2020 JT Rubicon, 1995 YJ
Hi Benny, I'm looking for the front driver's side door wiring harness which should be part #68299333AH for my 2020 Gladiator Rubicon with proximity entry, blind spot monitoring, power windows, power mirrors, power locks, and heated mirrors. Could you provide a quote? My local dealer is quoting $113 and I've seen it for around $60 online. Thank you!
