How’d you wire your ARB compressor?
Chocolate Thunder
Jeremy
I’m installing the ARB twin compressor under the front passenger seat of my JLUR. I’m curious as to how everyone mounting in that location ran the power and switch wires. Photos would help greatly. Thanks.
intentsrig
JLU Sporticon
I popped off the plastic panels along the bottom and did my best to run the wires through there. There is a part of the wire harness that is just free under the seat/ partly under the carpet.
I wired the power switch to one of my aux buttons and ran the actual hard wire power to the battery via a small gap in the windshield. Hard to push through but if you take off the passenger side engine cowl, you can see a small gap where you can push wires through from either direction. You also have to take off the side panel plastic inside the jeep. I'll have to look around to see if I have any pictures.
Chocolate Thunder
Chocolate Thunder
Jeremy
Thanks! I’m a visual learner, pics would help tremendously if you have any.
American Adventurist
West Florida
2018 StingGray JLUR
I made a new harness and ran it under the carpet, across the hump under the dash and out the firewall plug on the drivers side. Ran that across to reach the OEM switch pig tail. Aux 4 switch. Done.
Running the ARB harness through the floor plug is a bad idea IMO. Better to extend the wires and do it right.
MUD-H2O
Eric
Kansas City MO
2019 Wrangler JLUR 3.6L 6-Speed
Content Creator
I ran mine through the grommet on the passenger side. It comes in the firewall, goes behind the glove box, then under the carpet along the center console and then over to the compressor. It's wired to Aux 4.
I won't lie... This was a more complicated job than I'm used to and after failing at my first attempt, I paid 4 Wheel Parts to complete it. They bunged up the ends that plug into the compressor and I had to spend and hour or so bending them back into shape. But other than that it works great.
