Mitch F4C3
Let me just say you are killing it with all this info Russ. I greatly appreciate it. It would be preferable that they don’t go busting out rivets and all that. Honestly it would be most preferred if they just got a 4pin and did that. In my personal opinion a 7 is way too much for a Jeep. With the tow rating you shouldn’t be pulling a trailer with a braking system.@Mitch F4C3 : if you go the 7 pin harness route, I don't think the dealer has to go destroying plastic rivets like in the video I attached to peel back the front passenger's side fender, to get to the grommet in the firewall through which wiring gets from the engine bay to the interior or the rig.
First, I was able to bend back the fender enough without detaching it to poke a wire hanger through the grommet. (My wires were for another application, not the 7 pin wiring harness.) I suggest you tell your techs to use wire lubricant https://www.homedepot.com/p/Klein-Tools-Wire-and-Cable-Lube-Synthetic-Polymer-51015/100647818 here.
(Editorial note: it is utterly sad that the owners have to tell the techs. I see this as a product of FCA not giving them adequate pay and training, and that lack of pay not getting guys with adequate MOPAR experience. Many of us think twice about taking our new JLs to the dealer for a minor problem, concerned that they not only won't fix it, but make it worse. I second @Broccoli2 's sentiments here.)
Second, by removing more of the fender, if you must remove it at all, you can tap securing pieces that can be screwed back into place, not broken off.
