Hit and run, no real visible damage
jollycj
oakland
Jolly
My 2-door 21 Willys was hit in front of my house tonight.
The car hit the spare tire on the back and took off. No visible damage aside from the tire being scrapped up and part of the other cars headlight being torn off and laying on the ground next to it.
They hit the rear of the Jeep hard enough it moved a foot or so forward.. Wondering what type of damage I should check for? Rear tail gate operation, spare tire holder. What other things should I look and make sure aren’t bent?
Thanks in advance
Carolina Jeeper
Rollie
North Carolina
2019 Mojito! Jeep Wrangler Unlimited Rubicon
Electronics Technician at R. J. Reynolds
If it' has an automatic transmission I would definitely be checking that it's not damaged. The parking pawl in it could be damaged.
jollycj
oakland
Jolly
Thanks, it’s Manual so hopefully one less thing to worry about.
mqu02
Nebraska & Idaho
2021 JLR
Industrial Engineering
Check if it pushed in the back of the tailgate. My daughter got rear ended in her JK with a steel bumper and the bumper was fine but the spare tire was crooked because it bent the tailgate where the spare tire mount connected. The wheel and tire were fine, and the bumper wasn’t even changed. The other car was totaled.
jollycj
oakland
Jolly
Thanks
Bayrat
DA
NY and Fl
2023 Rubicon 392 - 2024 Gladiator Sport BAREBONES
That is a fairly hard hit to do what you are describing. I would take it to a body or frame shop and have it assessed.
Flip
Johnny
Virginia
2023 Jeep Wrangler Sport
Retired Power Plant Engineer
Just tell the insurance company you'll be needing new coil springs, high performance shocks, adjustable LCA's, custom driveshaft, rear bumper with tire carrier of course and if it's not too much trouble all new wheels. I'm joking.
I hope your jeep turns out to be ok.
jollycj
oakland
Jolly
Lol, well I do need those
Windshieldfarmer
Randy
Wichita, Ks
2015 JKU, 2020 JlU on order
I am optimistic your damage will be minimal. Last year while overlanding I backed into a pine tree pretty hard…hitting the spare tire. It hit hard enough I expected a damaged tailgate…at a minimum. Instead I only found residue and sap from the tree on the tire. While I have the factory reinforced tailgate, the hit was anything but a slight bump.??. Good luck!
