Here. Is the problem
James Vincent
jpvc5782#
2018 Jeep wrangler JLu
At times my Jeep 2018 JL 3.6 would have every dashboard light go on , would lose power steering , even go into limp mode , dealer has checked all connections , and keeps going back to powe steering pump is junk and causing the problems , is this possible and has it happened to anybody else , not sure if I want to fix it or just scrap the Jeep , and help is greatly appreciated
Tethmes
Dylan
Michigan
2022 JLWS, 2023 KLR650
Management
It's a 2018, you're out of warranty. Go to a real mechanic instead of a dealer and they'll have it fixed in an afternoon.
alphawolff
california
2021 JLU
Remove the grille and R/F headlamp. Loosen, clean, and tighten both ground studs you see there. Common problem, one of the grounds is for the EPS pump especially.
Seriously doubt your average mechanic could properly diagnose and repair something so unique to the JL/JT platform that's also intermittent. They'll throw a pump at it and when it comes back they'll say "take it to the dealer". Average mechanics are good for typical repairs, not odd-ball repairs.
Tethmes
Dylan
Michigan
Management
I said real mechanic, not "average". :)
jludave
The Isle of Long
IT Manager
Phrank
NEPA
2018 JLUS
Bad canbus or bad battery(s).
I had all of these issues and more - canbus was the culprit.
zw470
McFly
PA
'21 JLR
When my dash went into Christmas Tree Mode it was because of a bad steering column control module.
flyer92
Nevada
Did you confirm that all the fuses and relays are completely pushed in?
