Help with hitch for camper
Drewbacca
Drew
Nashville, TN
2024 Jeep Wrangler Unlimited Sport S 4xe
We have a 2024 Sports S 4xe and are about to buy a 2015 Shasta Airflyte Reissue. I’m trying to figure out what hitch to get for it. I know you can purchase weight distribution hitches and/or sway control hitches. I just don’t know if the camper is heavy enough for one of those, or both. I took some pics of the towing specs. I’m told the dry weight is 2,345 lbs, but it’s a little more on the tag. I just want to have the right hitch when I got to pick it up. I still need to get some measurements to figure out how much drip to get.
Jeep Wrangler JL Help with hitch for camper IMG_3791
Jeep Wrangler JL Help with hitch for camper IMG_3790
Jeep Wrangler JL Help with hitch for camper IMG_3789
Jeep Wrangler JL Help with hitch for camper IMG_3788
Jeep Wick
Wick
America
2022 High Tide XR
Mechanic
Draw Tite makes a nice Class 3 that is WD compatible. I believe it's the highest rated hitch out there and easy to install. Not sure you need sway control but the WD is good to have.
MtCamper
Ken
NW Montana and Yuma Az
2018 JlUR White Rubi, 2022 Chevy 3500, 2016 27-5L
Retired, Snowbird
Either a bolt on class III or a good hitch shop can make/modify the OEM Class ll. I'd go with a WD hitch with built in sway. I'm partial to Blue Ox. They make a sway pro 350 that should be about right. Really cute camper. "It hasta be a Shasta". Celebrated my first birthday in one similar to yours over 70 years ago.
Drewbacca
Drewbacca
Drew
Nashville, TN
I guess I’m trying to figure out if I need one. The cost is small compared to the camper, but it’s still not cheap. I just haven’t towed with anything smaller than a Chevy Silverado Z71 1500, so the Wrangler is new to me.
Jeep Wick
Wick
America
2022 High Tide XR
Mechanic
You'll want a good hitch and that's not expensive. Brake controller is the hardest part but even that's not terrible.
Grayhound
Michigan
Jlurd
This was my set up on my previous jeep a sport s. This camper is lighter than the Shasta.
I used a wd hitch from e trailer that was awesome! I also used a Bluetooth brake controller with a phone app for manual use, which I didn’t use.
The thing about the wd is it leverages the weight across the entire frame from back to front, like a wheel barrow.
On top of that I would air bag the springs as they are inexpensive. This will give you a level stable ride that you can safely take anywhere.
Jeep Wrangler JL Help with hitch for camper IMG_20200809_113109_Original
Drewbacca
Drewbacca
Drew
Nashville, TN
I want a decent hitch, but I also don’t want to go overkill. If I can use the stock receiver that came with the tow package, I’d prefer it. It looks like it’s a 2 inch Class 2, so WD hitches won’t work for it. The trailer has electronic brakes I’m told, so I should be good there.
GATORB8
CLT NC
21 JLURe, 06 LJ, 25 HDZR2
Do you have a brake controller?
GreenWilly
Tony
22 JLU Willy's, 2024 JLR
Check out Adersen WD hitch. It is much lighter Than a standard WD hitch.
Jeep Wrangler JL Help with hitch for camper 20230211_181714
Jeep Wrangler JL Help with hitch for camper 20230211_181646
GreenWilly
Tony
If it is a 2" receiver hitch, it is a class 3
GATORB8
CLT NC
You'd think, but Jeep classifies it as a class 2. It has the class 3 tube size, but class 2 weight rating and non-WD rating. (at least the OEM).
OrneryBear
Charles
Central OH
23 Sarge JLUR 6spd
what's odd is the curt class 3 hitch looks identical to oem.
GATORB8
CLT NC
So it's interesting to see them all be updated. Looking at etrailer, as of a year ago the only hitch rated over factory was the HD Draw-Tite, they've recently increased the Curt and house brand ratings to 5k.
