Help! This is driving me crazy!
Paulcardona
Paul
Colombia
JLU SAHARA 2023
So i just received my 2023 JLUS and i have this equipment:
FRONT LED FOG LAMPS
LED PREMIUM REFLECTOR HEADLAMPS
DAYTIME RUNNING LAMP LED ACCENTS
I can see in the headlamps the Halo lights, but i can´t get those to turn on.
I checked all forums but i haven´t see a problem like mine.
I can´t do it through Uconnect, i don´t have the option on the screen.
My dial in AUTO doesn´t do anything (just turn on the lights when is getting dark, but no Halo)
I suppose because this is a Latin America Equipment Group car, they disable it for some reason.
Can you guys help me to turn the halo on?
Or am i missing something?
Thanks a lot
Jeep Wrangler JL Help! This is driving me crazy! 20230121_120009_resized
Jeep Wrangler JL Help! This is driving me crazy! 20230121_120021_resized
Jeep Wrangler JL Help! This is driving me crazy! 20230121_120006_resized
TX_Ovrlnd
CStat, TX
'22 Zilver JLURD
freethinker
If you don’t have the DRL function in Uconnect then maybe a Tazer or JScan could? Have you checked all fuses?
AFD
Northeastern US
2023 JL Rubicon (2DR/V6)
Maybe a dumb question, but did you turn your vehicle to "run" before taking a look?
I didn't think mine were working either when I first got it, until I realized that just turning the park lights or headlights on with the vehicle turned off doesn't turn the halos on. Guess that's the "running" part of Daytime Running Lights ?
Paulcardona
Paulcardona
Paul
Colombia
JLU SAHARA 2023
I haven´t, i read here something about a 4th cable that maybe is not "connected", i don´t know where to check
hehe totally valid question, yes i checked every possible scenario, but no Halos in neither of them .. i don´t know what to do
  • Like
Reactions: AFD
Headbarcode
LI, New York
2019 JLUR Stingray 2.0 turbo
Was the parking brake engaged when checking the lights? That's the only way of shutting the halos off when the vehicle is running.
  • Like
Reactions: AFD
Paulcardona
Paulcardona
Paul
Colombia
JLU SAHARA 2023
The problem is i´ve never seen the halos work, maybe the are disable or not connected, that´s what im trying to find out
hoag4147
Colleyville, TX
2022 JLUR XR
FRONT LED FOG LAMPS
Thanks a lot
Unless something changed, it appears EU models not equipped
https://www.jlwranglerforums.com/fo...rcle-headlights-in-europe.76059/#post-1583264
hoag4147
Colleyville, TX
2022 JLUR XR
Can you help me checking the pictures I uploaded and see if the halos exists? I think I see it there but maybe I'm wrong
According to thread I attached the headlights nor harness have what is required to activate. Best way to verify is remove headlight and check for 4 pins on headlight and harness
NewJLU2019
Curtis
2021 Rubicon Unlimited 2019 Sahara Unlimited
I just checked as ADF asked about it. The jeep is in the garage so turned the lights on by hand and no halo.
Started Jeep with lights in auto and halos are on.
Khoder
Tony
Mopar321@
Wrangler rubicon 2023
Hi All,
I’m facing the same issue in my 2023 rubicon.
Halo lights are not working.
did you guys find the reason behind it ?
Thank you
AFD
Northeastern US
Just thought of something.. in addition to having the vehicle running, also try dropping the handbrake. Not sure what behavior this does with the JL, but in my last car, the DRL would not come on until the parking brake was released (obviously be careful doing this with a manual by having someone else look or sit inside with their foot on the brake).
Not 100% if this will do anything, but just an idea ?
(Shit, nevermind. Forgot that @Headbarcode already mentioned that)
Paulcardona
Paulcardona
Paul
Colombia
JLU SAHARA 2023
FRONT LED FOG LAMPS
Thanks a lot
Well, with the Jscan i tried every option possible and the Halos didn´t turn on...
Now im doubting if i really have the led light inside the halos (I haven´t pop opened the lights to check if the led is inside, in my pictures i think i can i see it, but who knows)
Only route it´s check if the 4th pin is installed (I have to take it to somebody who knows how to check that)
If everything fails, i´ll get the mopar us lights......Do i need to buy the complete set with the harnes? Or just the lights?
