Some Random Guy
- Sep 16, 2020
- Washington
- 2022 JL Sport, 2022 Ford Mustang
- Occupation
- Comptroller
I can use 6th at 55mph now. It is perfect for me, my commute’s max speed limit is 50 mph. If I moved to a more highway commute, gears would need to be changed to bring RPM’s down on the interstate.Stock Rubicon here. I feel the 4.10's are marginal. 6th only becomes useful 75+mph IMO. As smooth, quiet, and efficient the Pentastar is, running it at 2500-2800 on the highway really has no effect on comfort or mpg in my experience. I should note I have the SOT top which is not quiet on the highway.
Frankly the gear ratios in this trans are to widely spaced for the torque of the engine. I had a '79 Cherokee that I swapped a "wide ratio" NV3500 into. Those ratios were about perfect. Never seemed to lug the engine unless I did something wrong. The D478 has a wider ratio spread, which results in the not torqy engine lugging in a lot of scenarios.
@Some Random Guy , would you attribute your highway performance to gears or tire size?
Pete
